Old 04-21-2003, 02:15 PM   #1
Linus0014
Guest
Posts: n/a
Engine Fire
I was driving down the road two days ago when my engine shut off. I thought it was something small, so I tried to start it again. I get out and see smoke coming from the hood. I put up the hood and see my engine is on fire. The only thing I see is a hose from someones house. I end up putting it out, of which I'm told not to use water b/c it will spread. But I can't sit there and watch my truck burn to the ground.......Rebuilt motor w/ all new pumps, starter alternator. Edelbrock: intake, carb, and heads. When I finally get it towed home I see my spark plug wires are where I think it all started from. Now I have the task of cleaning and finding if it might be something else....Any suggestions??
Old 04-21-2003, 02:24 PM   #2
fast67chevy2002
Dad's little helper
fast67chevy2002's Avatar
sorry to hear about the fire, my 77 caught one time and it was a hot wire on the fire wall that sparked gas leaking from a gasket on the carb, you might want to check if something of that nature was the start.
fast67chevy2002 is offline   Reply With Quote
Old 04-21-2003, 02:44 PM   #3
Linus0014
Guest
Posts: n/a
thanks, I'll check it out
Old 04-21-2003, 03:39 PM   #4
Southpa
Southpa's Avatar
You say your engine shut off. Were you still rolling and in gear? That happened to me once, but no fire. If the engine stalls while in gear that means the crank is still turning. That also means that the crank is still pushing the mechanical fuel pump. The end result is gas gushing out the carb, .
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 04-21-2003, 03:53 PM   #5
cdowns
cdowns's Avatar
sorry about the fire !!! i learned the lesson 30years ago with old leaky stromberg carburators i ALWAYS carry at least 1 most of the time 2 fire extinguishers in each vehicle boat car truck they've all got them real cheap insurance hopefully you can get it back together inexpensively and maybe others will read this and take a clue and get themselves extinguishers
Old 04-21-2003, 06:12 PM   #6
Stout72
Not my good side.
Stout72's Avatar
Don't worry too much about using water to put out a fuel fire if that's all you have at your disposal. If you have to use water, use a spray pattern and stand back. A forcible stream will indeed spread the fire, where a spray or mist will cool it and work toward displacing available oxygen (2 of the 3 sides of the fire traingle).
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 04-21-2003, 07:30 PM   #7
Jackal2k9
Jackal2k9's Avatar
good to know a fireman... certified or not.
Jackal2k9 is offline   Reply With Quote
Old 04-21-2003, 09:03 PM   #8
Blue Beard
Blue Beard's Avatar
Keep us posted as to what you find that may have been the reason.
After some of the posts I've seen, my question would be Did you have one of the glass fuel filters? Everyones under the thoughts these are bad.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-21-2003, 09:13 PM   #9
Linus0014
Guest
Posts: n/a
I will. So far I think the spark plug wires are what started the sparking and then it started burning the fuel line. So when the fuel line started to burn it exploded and sent fuel everywhere. Good thing I dont have an electric Pump, huh?
Old 04-21-2003, 09:20 PM   #10
Blue Beard
Blue Beard's Avatar
I converted my from hose to tubing. Have habit of doing that on all my rides rather than taking a chance on a rub spot or any likeliness of that type of thing happening.
Have seen fires where the tubing came off a fitting because someone didn't clamp it right.
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 04-21-2003, 11:46 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Glass fuel filters are fine if you think about where you put them. If you place it within an inch of something harder than the glass, you deserve a fire. If you'r smart enough to bend the lines away from the engine and have it away from everything, the glass filter is a very handy way to go.
Old 04-22-2003, 10:31 PM   #12
Linus0014
Guest
Posts: n/a
I think I'm gonna go back to the metal gas lines. But how do I go about making my own. What tools do I need and fittings, and size tubing? Flaring tool, cutting tool?
