12-04-2011, 09:40 PM | #1 |
What radio to use?
My dash has been modifeid with hammer and chisel by someone to install a single din radio. I have a section from another dash that has good radio opening. I'm not sure if I want to do the surgery for the stock radio or if I want to do something different. What are you guys doing about radio? What model do you call a 1952GMC? Thanks
12-04-2011, 09:54 PM | #2 |
Re: What radio to use?
My dash is going to be all changed around with a different dash with custom instrument panel so that doesn't help but I am planning on a swing down cover to hide the radio's face panel. I'd repair the dash, use a radio delete plate and then make a panel to hold the radio to go under the dash or maybe a console to go up in the roof to hold the radio up out of sight from most eyes.
12-04-2011, 11:18 PM | #3 |
This a dash in a '55 chevy using a custom auto sound radio... if you fix your dash it would look like this...
12-05-2011, 02:24 AM | #4 |
I think by his first post he has a 52' gmc, so his Advance Design dash would obviously be different.
To answer the original question I personally would restore it to the original form, but it completely depends on what your plans with your truck are, good luck! |
12-05-2011, 02:35 AM | #5 |
Thanks Maximus, didn't see the '52 line... in that case i can only show you a '51 with the stock block off plate, but we still used the custom auto sound r.adio that you can hide anywhere
12-05-2011, 06:03 AM | #6 |
heres mine 54 gmc. had an extra speaker grill so i modifyed it to fit my radio.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
12-05-2011, 09:14 PM | #7 |
Hey Parkwood both those are good looking dashes. Is that a custom audio sound radio in the 55 dash? Does custom audio sound also make the hidden radio? Is that what you are using in the 51 dash? Thanks. Scott
12-05-2011, 09:53 PM | #8 | |
On the '51 we put the unit under the seat and the face of the radio in the glove box.. the '51 came with an iPod hook up. |
12-05-2011, 10:06 PM | #9 |
put the speaker face on a hinge an build a 2 inch box an install on the back side of the dash, i did mine 2 inchs so u have a place to put keys r the remote for the radio, when you close the speaker face nobody will see the radio, if u get a radio with a remote u can work it with the speaker face closed
12-05-2011, 10:16 PM | #10 |
Old Heap Driver
I went with XM radio in my 50. Made a backing plate out of some ABS plastic, bolted it in place where the radio knobs would go. the XM unit is held in place with double sided tape. An old Pioneer amp under the seat provides power to a pair of 6X9's behind the seat. A volume control from PAC (LC-1) keeps the tunes at the correct level. I can move the XM unit from car to car, I love it.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
12-05-2011, 10:26 PM | #11 |
heres 2 pics that should give u an idea
12-06-2011, 11:57 AM | #12 |
I used a JBL marine audio and put the remote in the glove box. I also have a wireless remote so that I can change songs, volume, etc. I was originally going to use a hidden audio unit but, had read several reviews where the sound isn't all that great.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
12-06-2011, 11:59 AM | #13 |
i would go with a hinged radio delete plate to keep it looking factory . and put a radio with an ipod hookup behind it. nobody uses cds anymore.
Posted via Mobile Device |
12-06-2011, 02:15 PM | #14 |
Look at kustombrads thread, he made a slick opening center dash grille.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
12-06-2011, 06:40 PM | #15 |
Old Heap Driver
Link?
12-06-2011, 09:00 PM | #16 |
i plan to use my Droid for Pandora in my truck and run it through an amp that I'll mount under the seat.
Parkwood, this is off topic but that under dash unit is different than the "standard" vintage air unit, was that a custom order thing from V/A? I believe the standard has those cheap looking knobs.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
12-06-2011, 09:33 PM | #17 |
Search function will find it but here is a link that shows the door. Earlier in the thread he has more detail.
http://67-72chevytrucks.com/vboard/s...&postcount=403
12-06-2011, 09:44 PM | #18 | |
Old Heap Driver
12-06-2011, 10:38 PM | #19 |
Renegade6. That is a good idea. on the 1952 GMC dash would you smooth the original radio hole and eliminate it or use the factory delete? Thanks.
12-06-2011, 11:08 PM | #20 |
I think it depends what look you are going for. If you want to go custom, I would fill and smooth it otherwise use the delete plate.
12-07-2011, 01:44 AM | #21 |
gear drive , big solid-lifter cam and flowmasters turned down under the bed .....i dont think im even gonna put a radio in !
12-07-2011, 10:37 AM | #22 |
Hey guys thanks for the input!
12-07-2011, 11:37 AM | #23 | |
Except for the 4" megs I used for exhaust tips!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
12-17-2011, 12:44 AM | #24 |
Thanks for the input. I patched the damage with a piece from anothe ND dash. Now I need to find a suitable radio. After doing some searching I wished I would have smoothed the radio hole. I have not found a suitable radio to fit the original opening. Any ideas on what brand to use???????
