Old 12-04-2011, 10:34 PM   #1
Envy
Envy's Avatar
Factory air-gauge with airride?
I want to use a factory air gauge for my 65' build. The gauge is the type that comes in the c60 trucks with air brakes and only reads up to 150psi.
the question is, since i have a 200psi system, is there a method of regulating the pressure input to the gauge or can the gauge handle the extra 50psi and just peg out?
Envy is offline   Reply With Quote
Old 12-05-2011, 12:03 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Factory air-gauge with airride?
I would use a regulator either at the tank or under the dash to protect the factory gauge.
Maybe a small air compressor style regulator?
http://www.facebook.com/notes/ordern...14437931900737
Keith
Convert to disc brakes.
Old 12-10-2011, 06:51 PM   #3
Envy
Envy's Avatar
thats what i was thinking. I wish i could just get a simple in line regulator that was preset, so it would look like no more than a fitting. But i havnt found one for 150psi.
Also, would i need some sort of water separator/filter to protect the gauge?
Old 12-10-2011, 07:06 PM   #4
lolife99
lolife99's Avatar
I wouldn't think so.
Air,... is air.
That's what these gauges were designed for.
Keith
Old 12-10-2011, 08:02 PM   #5
SCOTI
SCOTI's Avatar
Do you need the 200psi? If not, install a 150psi or lower pressure switch @ the compressor or tank.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
