Old 12-04-2011, 10:55 PM   #1
gag1025
Exterior Rubber Window Wipers Installation
I bought a pair for my '53 truck, and after looking at both side windows cannot figure out how they attach. The interior felt ones are stapled or screwed on to the interior molding but I am not sure about the exterior rubber ones. Anyone who can help? Thanks in advance.
gag1025 is offline   Reply With Quote
Old 12-04-2011, 11:14 PM   #2
parkwood
parkwood's Avatar
Re: Exterior Rubber Window Wipers Installation
drill a very small hole and hold them on with small screws... a lot of places that sell the kits also sell a special drill with a stop (so you don't go through to the outer door skin) and the small screws to hold them in place..
parkwood is offline   Reply With Quote
Old 12-07-2011, 12:23 PM   #3
solidaxel
solidaxel's Avatar
Don't forget the rubber wipers just below the window opening in the door, it slides in from the center
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-07-2011, 04:13 PM   #4
gag1025
Straightaxel, thanks for the reply. Those (outer rubber wipes) are the ones I am talking about. What do they slide in to? All I see on the door frame (outside part) is a lip that is a slight V shape at the bottom. Plus the fact that there is the part that sticks out (a brace). I am attaching a couple of pictures of what I see. Does the bottom of the rubber strip fit into this V shaped groove? Do you glue the bottom in with Loctite adhesive or clear silicon or as was suggested do you attach it with screws? Do you install it before putting the window assembly back in or after the window glass is in place? As you can see this has me baffled. The felt (interior) wipes were easy to install to the interior molding, but the outter rubber wipes are not as easy to figure out. Thanks for all your help.
[ATTACH]Name:  DSC00205.jpg
Size:  25.9 KB[/ATTACH]
Old 12-08-2011, 09:42 AM   #5
solidaxel
solidaxel's Avatar
That does not look like the doors on my 55 or 53, show us a pic of the rubber wiper, end view
My doors had a channel and one large end on the rubber that slid into the grove in the channel from the center, left and right
LS 3 4L70E
Old 12-09-2011, 03:32 PM   #6
gag1025
This is about as good as I can get a photo of it. As you can see looking at the end, one side goes straight down while the other side flares out.
Old 12-11-2011, 06:51 PM   #7
gag1025
Good news. I found out how to slide the rubber wipe into the groove. Using a thick soap and water solution made it go in much easier. I actually thought that my door had the top of the channel missing but the top lip serves as the top part of the channel. A poor design but it fits so I am happy.
