Old 12-05-2011, 12:29 AM   #1
LEEVON
LEEVON's Avatar
Cowl vent is stuck
The cowl vent on my '50 is stuck. All the parts are there, I stared and scratched my head for awhile but didn't touch it. I don't want to break it or bend any of the brackets, but I'm not really sure where it pivots and how to get it unstuck. Maybe it's the seal or maybe the brackets, not sure. Anybody have an idea?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-05-2011, 04:54 AM   #2
Daze57
Daze57's Avatar
Re: Cowl vent is stuck
spray it very well with p b blaster - or even some W-D 40 let it set a few hours or a day .- repeat then give it a try -CAREFULLY - ya dont need to force it or break it ,
good luck !
Daze57 is offline   Reply With Quote
Old 12-05-2011, 02:32 PM   #3
Spackle100
Ditto with the PB blaster. I used that on my vents too....and the rest of my truck...
Spackle100 is offline   Reply With Quote
Old 12-05-2011, 02:51 PM   #4
MrTucker
MrTucker's Avatar
I very lightly pried it loose with a screw driver - it popped out without damaging anything at all. With mine, the gasket dried out and just made everything stick together. But trying to force it open with the lever didn't work, as caused the lever linkage to come apart
1953 GMC 1/2 ton long bed
Original 228 I6 with a Hydramatic Auto Tranny
Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649
MrTucker is offline   Reply With Quote
Old 12-05-2011, 09:24 PM   #5
BlueJeep
BlueJeep's Avatar
After breaking off the rotten plastic knob, I was able to get a crescent wrench on the handle and work it loose. Go slow and watch what is happening, and stop before you cause damage.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-05-2011, 11:09 PM   #6
mknittle
mknittle's Avatar
pb blaster let it soak and do it again!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-06-2011, 11:10 AM   #7
52 Rat
52 Rat's Avatar
Same here, I soaked mine with WD40 and kept spraying it over a period of a week. I was able to slowly start moving the handle and was able to get it open.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 12-06-2011, 01:29 PM   #8
Daze57
Daze57's Avatar
all it takes is a l'il time and patience - work it a little at a time - it'll bust loose - the tight ones usually do .
Old 12-08-2011, 06:14 PM   #9
LEEVON
LEEVON's Avatar
Thanks guys. Yeah, time and patience I'm always short on those but I have plenty of PB blaster, strong arms and a hard head...which might explain why I like to break things after getting them greasy, wearing out my arms and hitting my head.
I'll shoot it tonight and wait a couple days and try again. I wouldn't be having this problem right now if I had installed the brake and clutch pedals BEFORE welding in the support like I had planned. Now I am praying that once the vent moved the lever will be out of the way enough to slide them in.
Old 12-09-2011, 10:37 AM   #10
beanyard
My passenger side is stuck half way open/closed I think I will be trying the methods above prior to replacing the cable.
beanyard is offline   Reply With Quote
Old 12-09-2011, 02:24 PM   #11
Daze57
Daze57's Avatar
yeah just work it a lil at a time - itll eventually work loose - good luck !
