Old 12-05-2011, 10:32 AM   #1
Tucson38
Neutral start switch override
While I recognize the reason this switch is in place, the switch in my '85 GMC has failed twice, once while I was on a 4wd outing. Here's my solution:
There are two wires leading to the switch, purple and yellow. I put an inline tap on each wire, terminating with an (unconnected) male/female quick connect fitting. Now if the switch fails I can just reach under the dash, connect the two wires and good to go. Could have been more tidy and connected the terminals to a switch but it's an emergency override so I just went with the connectors.
Tucson38 is offline   Reply With Quote
Old 12-05-2011, 11:30 AM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Neutral start switch override
The PO put a fuse in the factory plus so that it would start without pressing in the clutch.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
