04-21-2003, 02:59 PM | #1 |
Seasonal Poster
Push Button Ignition?
Has anyone ever wired up a push button ignition on their truck?
I really want to try this, but I suck with electrical on my truck and was wondering if its a tough job or not? If you don't know what im talking about, I mean push button as in like on the Honda S2000's
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW Last edited by MandarinSixSeven; 04-21-2003 at 03:08 PM. |
04-21-2003, 03:19 PM | #2 |
A buddy of mine is running a push button switch for his ignition on his B&M shifter base plate on his '60 Impala. He has it wired up so that he still has to put the key in and have it turned to on but he took the wire that goes to the started and routed it to this push button switch. I think it is a sweet idea.
Jeremy '71 C-10 '72 GMC K2500 '72 Nova (Dad's) '70 Chevelle SS '55 Sedan Delivery Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall |
04-21-2003, 04:30 PM | #3 |
Spank 'em if you got 'em!
You will still need a key or some kind of switch to turn on the acc. Then you can just run your starter wires to your push button. Simple installation, just make sure your locks work! Then again, it only takes a sec. to hot wire our trucks anyway. Good luck!
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
04-21-2003, 05:19 PM | #4 |
Mine is push button start. I did not wire it the previous owner did. Its wired to a toggle switch also where the switch has to be on for it to start. He was to friggen lazy to figure out how to wire it to the ignition. It can be a pain in the butt sometimes because my door locks don't work and when I go fishin or somewhere in it I always worry someone may try to steal it. I say go for it, just don't do it half-assed with a toggle switch.
1972 GMC SWB, 305 powered 1980 diesel VW pickup, Needs a Heart Transplant 1997 Toyota Taco The Second Amendment is in place incase they ignore the others. |
04-21-2003, 05:19 PM | #5 |
Seasonal Poster
Ya ok, thats all i was hoping it was...now, does anyone know which wire I would have to route to the switch, I still want to have to use the key, but just push the button instead of turning the key to start. There are some fat wires on the back of the ignition switch, and I have no idea which one is which...Any help would be greatly appreciated
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
04-21-2003, 05:23 PM | #6 |
Should be easy. We did it to an old Honda Civic because the contacts were shot on the start function of the switch. The switch is part of a multiple function switch setup and costs and arm and a leg. The rest still worked so we just set it up with a pushbutton on the dash. Turn the key on, push in the button until it starts and let go of the button. Simple.
1968 Chevy - 292 with a powerglide |
04-21-2003, 05:26 PM | #7 |
Seasonal Poster
Hmmm...ok so does anyone know what wire? Cause I'm all set to do it, I just dont know what wires to splice etc...I'm waaaay to scared to do it without proper guidance. If it was a computer, I could do it no prob, but with my truck I'm paranoid, knowing me, I would hook it all up then...nothin! I'm anxious here guys please tell me tell me
04-21-2003, 07:35 PM | #8 |
I finally got an avatar
All the GM vehicles I've worked on, the wire to the starter was purple. Just pull power off from a hot source and connect the other side of the switch to the purple wire.
-72 C-10 short step (straight line only) 12.922/102.28 -69 C-20 on Propane (DD) -69 C-10 -56 Mack B-753LS (tow rig) -94 Chev K2500 Short Ex-Cab -89 Isuzu Trooper...Kinda -03 Kawasaki KFX-400 -05 Suzuki DRZ-400S |
04-21-2003, 07:57 PM | #9 |
I am a Referee of life.
Make sure you use a switch rated for the amp draw.Many trucks in the late 40's early 50's had the set-up you describe from the factory.Some even used a switch like the floor mounted dimmer switch that was under the acelerator pedal.You started the truck by flooring the gas.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-21-2003, 10:05 PM | #10 |
So to unwire it from a button back to the ignition do I just take the wire from the button that leads to the starter and splice it to the purple one? If so then I think my key start thing(Can't remember the exact name for it right now) may be bad because I tried that today.
04-21-2003, 10:49 PM | #11 |
Seasonal Poster
Ok, so what is the wire from the 'On' position of the ignition? Like what wires would you use so that you have to have the key in the on position before you could hit the button?
04-21-2003, 11:34 PM | #12 |
its all about the +6 inches
On the harness going to the IGN switch, there is a large pink wire. Tap into this wire, it can support the load. You'll need to run power from it, and not just disconnect it all together.
Run your new wire from the pink, to your starter button, and then run the wire from the starter button to the starter. You'll see a purple wire on the starter, it should be on the S trminal. Bolt your wire here. You will still need the key to do anything, the button won't have any juice at all untill the ign switch is in the on position. |
04-21-2003, 11:40 PM | #13 |
Seasonal Poster
Awesome!
So just to clarify...run pink to button, then button to purple? and that should work? What do you mean by S terminal? Sorry to be such a bother, but I really wanna do this right. Thanks, Benson
04-22-2003, 12:39 AM | #14 |
Well, the pink wire has to keep going where it was going, you just need to tap into it. But the wire coming off the pink term, to the button, then button to the S terminal.
When you look at the starter, there will be up to 3 wires on it. The main battery positive cable. the Yellow wire on the R terminal which you wat to remove if you have HEI ignition, or not mess with if you still have points. And the purple which is on the S terminal. |
04-22-2003, 12:56 AM | #15 |
Seasonal Poster
Ok, one more question...
when you say remove the yellow wire, do you mean remove it when installing this button if you have HEI? Or do you mean, it should not be there if you have HEI at all? I do have HEI...
04-22-2003, 01:00 AM | #16 | |
Bloo
it doesnt need to be there at all if you have HEI, none of my trucks have em and they are all HEI/keyed ignition... the S terminal with the purple wire, SHOULD be the one closest to the block...
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
04-22-2003, 01:26 AM | #17 |
Seasonal Poster
ok, thank you very much!
I think I should be able wreck, I mean install that now. Ill tell you all how it goes
04-22-2003, 01:48 AM | #18 |
i love summertime
where you gunna put the button benson? you have a button allready? we got one at my dads, he got a mid 60s byscaine* donar car for running gear for the 53, and the previous owner had a nice little chrome button, let me know and ill see if we can find it
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
04-22-2003, 03:09 AM | #19 |
14.1 @ 96MPH
No terribly useful info...but the ignition on my girlfriend's Opel is set up the same way because ignition switches for it also cost an arm and a leg. Now, it's just rotate the key to on (there's not a stop until you get pretty much 180, not even a notch) and push the button further down on the column...works well, IMO.
I think it's a cool idea. Personally, I think a really cool setup would be to have the entire ignition cylinder be the button...turn the key, and then push the whole thing into the dash...crazy, I know, heh.
Project1970 - LS1 Swap Complete! |
04-22-2003, 07:19 AM | #20 |
When my 71 Monte was still alive I had the same problem as Project1970's Opel. The ignition switch was broke and I didn't want to buy a new one. I wired up a remote starter switch from my tool box. You just put the key in the run position and hit the button.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
04-22-2003, 09:04 AM | #21 |
You shouldn't need a heavy amp button. Those are for old tractors and REO Speedwagons without cylinoids. You know what would be neat though, throw your friends off too, is to put a push button on the floor! Tell them your truck just knows when your ready to go and starts right up!
Green72GMC, have you thought about installing a battery kill switch under your dash or seat. I've even heard of people putting them in their glove boxes. Just an idea.
