Headers or Manifolds?
Im close to putting my 383 engine on the frame and bolting her up, which brought a question to mind, what would be better headers or stock exhaust manifolds. I personally like the hearder better but ive heard they have the tendancy to leak.
What would be the best choice, what hearders are the biggest bang for my buck, and what kind of, if any fabrication would i need to do to get headers to fit
1967 C10 Long Bed, Soon to have a 350 1997 Chevy 2500 454 BB |
Re: Headers or Manifolds?
my truck has headers, but the previous owner was a lazy bastard because he used the normal 6-sided bolts to fasten it. they won't fit, because the header pipes have a larger diameter so the bolt rub up againts the pipe. this leaves you with two options:
put a dent in the pipe so you can get a normal socket on the bolt to tighten it, so secondly (what lazy bastard did) tighten it with an open spanner..yes they where leaking ![]() So I got myself some allen bolts (hope that is the right name) and felpro gaskets to keep it closed. when choosing headers take a good look at the thickness of the connection plate, it should be around half an inch to keep it from distorting from the exaust heat.
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
For a 383, I'd say headers for sure. My pickup use to have headers (PO), but were replaced with ramhorns. BUT, you can see on the passenger side frame rail, a "notch" was cut out to accomodate headers. I've seen this EXACT same notch on another build too. Not sure I have any pictures in my build thread that show it, but you can check.
project: "my happy mess" |
My 70' blazer has headers, they don't leak, yet. Soon as i get extra funds i will return to factory style ramhorns. Probably the 2.5 version i've seen.
Go with the Summit ceramic coated they look great and fit nice . They stop just past the cross member not like the long full length headers that hang down.
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
![]() Join Date: Sep 2010
I love the simplicity and reliability of the rams horns
I had headers on my 72 with the "standard" 3 bolt header collector and I had to replace the collector gaskets fairly regularly to keep the sealed up.
On my 68 I have headers too. I welded on flowmaster ball-flange collectors and have no leaks...and no gaskets to mess with. For a 383 I'd definitely go with headers. I also saw on a thread where someone mentioned putting teflon tape on the header bolts to keep them from loosening up, but I haven't tried it. |
What kind of headers would you guys recommend, what would fit the easiest
#9 | |
#10 | ||
"I ain't nobody, dork."
I've had headers on every single vehicle I've ever owned. Early on (teenage years) I learned that overtightening fasteners warps flanges and causes leaks. After I figured that out... I have not had one leak in the last 25 years.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Do you have the summit part number? Thanks,
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Gary, What are your torque specs on those headers. I used to bend them as a teenager myself.
1968 Chevy C/10 LWB V8 ![]() 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
#13 |
2 1/2 center dump exhaust manifolds
#14 |
I had a 69 C20 with a small block and couldn't keep the header bolts tight,,, I used blue loctite. I changed the motor a couple of years later ,, the bolts were still tight and came loose with no problems. Another option is a mechanical lock like the Karr locks from Karr products. They are a 2 piece washer type lock that work great ! Hope this helps some !! Tom |
#15 |
Brand Hooker Headers Manufacturer's Part Number 2452HKR Part Type Headers Product Line Hooker Competition Headers Summit Racing Part Number HOK-2452HKR UPC 700414008271 Header Style Full-length Header Material Steel Header Finish Painted Primary Tube Diameter (in) 1 5/8 in. Collector Attachment 3-bolt flange Collector Diameter 2.500 in. Tuned No Primary Tube Length (in) 27 in. Primary Tube Gauge 16-gauge Cylinder Head Port Shape Oval Flange Style Standard Flange Thickness (in) 5/16 in. Bolts/Studs Included Yes Gaskets Included Yes Reducers Included No Y-Pipe Included No Motor Mounts Included No Transmission Mount Included No Quantity Sold as a pair. |
#16 | |||
On the header flange at the head, I always start with the 2 inner bolts next to the siamesed ports. Then go outward from there. Again I snug them tight and use the soft thick aluminum gaskets. I've used the soft copper ones too with good success. But they are more spendy. Gary
#17 |
#18 |
I'll second that. I would do 2 1/2" dump before headers.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#19 | |
1. The difference between the rams horns and the headers is negligible up through most of the 3000 rpm range. 2. My truck rarely if ever sees more than 3500 rpms. My conclusion is that if you constantly run that engine over 4000 r's go with headers and the headaches that come with them. If you're like 99% of us out there that drive our truck around normal and legal, get a set of rams horns.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#20 |
I have center straight dump manifolds on mine. I don't know if they'll work on a 2X4.
#21 | |
#22 |
One of the First
![]() Join Date: Jan 2000
X3 - thats what I run on my Blazer /2.5 corvette straight dumps, better flow for a DD and no leaky. If you go that way, shoot me a PM and I will give you the P# for the right gaskets.
But, I get carried away in 3rd gear sometimes... What - gas mileage!! ![]() |
#23 |
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
#24 |
It would seem that a daily driver and maybe a little red light to red light one would not see much over about 3500 RPMs and would not "feel" much difference between stockers (2.5") and headers. That being said today's headers with 3/8s - 1/2 inch flanges and ball sockets are virtually leak free unlike the headers of even 10 years ago.
#25 |
This is the number for the ones I bought SUM-G9006-9 they are Summit brand and for the price $219.95 and look I would not buy the painted ones.
http://www.summitracing.com/parts/SUM-G9006-9/
