10 20 30 1/2 3/4 1 Ton
Ok I wanna figure this out finally, ive always figured 10 is half ton, 20 is 3/4 and 30 is 1 ton but I've seen some odd things like a 20 with duals....so?
http://67-72chevytrucks.com/vboard/s...d.php?t=438550 ![]() ![]() 1994 Buick Roadmaster 1994 GMC Sonoma |
Re: 10 20 30 1/2 3/4 1 Ton
Gmc did the 1500 2500 3500 thing that should help in the confusion. That might lend to the theory that GMC trucks are tougher[ can you hear the worms coming out of the can I just opened?] Auctally , most of that about GMC being better goes back to a time when they had air filter systems that worked better and that made the engines last longer. any way, back to your question I don't think the dual wheels were ever a 3/4 ton option i've never seen one. Most likely you saw one that someone put heavier stuff under.
The 10,20 and 30 number all represent GVW weight ranges. For GM of this time period I'm showing:
1-3900-5800 lbs 2-5200-7500 lbs 3-6600-14,000 lbs And yes, it was possible to order dual wheels (RPO RO5) on a C20.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
its all about the +6 inches
Drw could in fact be ordered on a c/20 if it was a cab/chassis only.
You are right on the half ton being a 10, a 3/4 ton being a 20 and one tons are 30 series. Posted via Mobile Device |
I shoulda hit refresh first huh?
Old Duffer
![]() Join Date: Mar 2003
Well, seems there's exceptions to everything. Here's a couple pics of the original paper work that came with my truck. There were 1103 flatbed C20's ordered in 1968 (according to the resto-pack people), and the dual rear wheel conversion was available at the factory. Chevrolet didn't keep track of anything that was less than 1% of a production run so it didn't happen very often, but there's 11 or less of the factory C20 dually's running around. I know of two.......
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
You guys know a lot more about these big trucks than me by far .,,.but what the heck does "dual rear chassis provisions" really mean ???
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
longer wheel studs to acomidate 2 rims in the rear, mabey??
