Adding brake booster to 67
Master cylinder went bad so while replacing figured I would add booster. When I pulled mc off, the rod is smooth, no holes or threads. So how do I connect my brake pedal rod to booster pump
Posted via Mobile Device |
The Older Generation
Re: Adding brake booster to 67
I think you will have to get a pedal to booster rod for power brake setup. If the booster you bought was a used one you always want to make sure it has the original pedal to booster rod with it. LockDoc
