Old 12-05-2011, 06:43 PM   #1
INSIDIOUS '86
INSIDIOUS '86's Avatar
front brake rotor sourcing
does anybody know where I can get front brake rotors that dont have the outer bearing cups already pressed in? is there a way to get these out?
reason i ask is because i want quality timkin bearings and not the no name brand you get supplied from schucks(O'realys) or napaww auto parts
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-05-2011, 08:33 PM   #2
78 Chevyrado
Re: front brake rotor sourcing
you just press the cups out with a press out or tap them out with a brass drift/punch. look at the backside of the installed bearing cups, there are notches in the cast iron giving you access to knock them out from the back. don't use steel drifts/punches on them or you may damage them. use brass if possible.
78 Chevyrado is offline   Reply With Quote
Old 12-06-2011, 02:50 AM   #3
INSIDIOUS '86
there are no notches on the new ones to punch them out, ive tried last thing im worried about is damaging some cheapo no name bearings
Old 12-06-2011, 10:44 AM   #4
78 Chevyrado
There isnt any access at all to the back of the cup? not even a thin ring around the edges? If theres no lip at all behind it, you'll need a "blind bearing puller"
Reason I say not to damage the bearing race is because if you damage that taking it out, you have likely damaged the rotor too.
Here's a link to the puller. you'll have to make sure the collets will fit your bearing cup though.
http://www.harborfreight.com/blind-h...ler-95987.html
Old 12-06-2011, 01:01 PM   #5
Pro Performance
Pro Performance's Avatar
I usually try and punch them out through the front side. If you're replacing the races, then it wont matter if they get damaged.
If you're trying to remove the front bearing race, I have used a socket that has the same diameter to knock it out from the backside.
Pro Performance is offline   Reply With Quote
Old 12-06-2011, 01:57 PM   #6
tucsonjwt
Just a thought, have you priced OEM GM or Delco rotors from the usual suspects?
www.oewarehouse.com
www.oehq.com
www.rockauto.com
www.gmpartsdirect.com
Or do a google search for the GM part number? I have found some good deals on the above or Amazon, OEM vendors found on google.
tucsonjwt is offline   Reply With Quote
Old 12-07-2011, 04:02 AM   #7
INSIDIOUS '86
I dont care about what happens to the chinese bearings just would like a way to get them out. the only reson my friend didnt buy online is wee needed to get his truck running in a couple of days and price and time was an issue
just fugured if we can get that preinstalled crap out of the rotor we can put in timkins and breath easy over bumps and not wory for years
