Old 04-21-2003, 04:40 PM   #1
racindego
custom front suspension
Next winter, im planning to build a custom front suspension for my drag truck, 67 c10. I currently have djm tubular control arms, but i plan to modify them, notch my crossmember, and fabricate mounts to run coil overs. I am after a ride height similar to what I have but with more suspension travel and better geometry. has anyone done anything like this or maybe converted to mustang II or pinto suspension? pictures would be great.
thanks
michael
racindego is offline   Reply With Quote
Old 04-21-2003, 06:35 PM   #2
CustomChevy
I am working on a project that includes changing to MustangII front suspension, although I am also building new frame for it as well. The stock frames on a pickup would need to use rack extenders and you can get bolt-in kits from Fat Man Fab. (www.fatmanfab.com) These are somewhat pricey, but you get the full meal deal.
Alternatively, HAL/QA1 makes a coil-over conversion kit for GM, though the application invloved is not a truck. Probably could get something to work using some car components if necessary. Summit actually carries this kit.
Part # HAL-GMP11 $457.00
Good luck!!
CustomChevy is offline   Reply With Quote
Old 04-21-2003, 10:07 PM   #3
racindego
thanks for the suggestions, definately some possibilities
michael
Old 04-22-2003, 12:43 AM   #4
68LSS1
68LSS1's Avatar
I've got a Fatman Stage III set up temp installed on my frame right now. Polished Mustang II tubular A-arms and coil overs. Cab and front end is off frame . Can't post any pix but can email some if you want them.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 04-22-2003, 01:17 PM   #5
racindego
that would be great. my email is mab39@drexel.edu
thanks
michael
Old 04-22-2003, 11:44 PM   #6
68LSS1
68LSS1's Avatar
Pix sent. Need anything else (more/specific pix, measurements, etc) let me know.
'68 Short Step
Old 04-23-2003, 07:32 AM   #7
racindego
thanks for the pictures, exactly what i was looking for to get some ideas.
michael
Old 04-25-2003, 04:24 PM   #8
68racer
Yeah baby!
68racer's Avatar
Try www.jimmeyerracing.com for some good ideas.
I will mail pics.
11.37 @116
68racer is offline   Reply With Quote
