Old 12-05-2011, 08:50 PM   #1
Breadman
Breadman's Avatar
Dash Lights Not Working
I have changed the circuit board and still no dash lights.The turn signal
bulbs work and the oil,temp alt and gas gauge work. ..HELP
Thanks in advance for any help
EVEN JESUS HAD A FISH STORY...JOHN 21: 6 and 11
Bass in picture is a 11.4 pound largemouth bass
I caught March 13 2014
Breadman is offline   Reply With Quote
Old 12-05-2011, 08:53 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Dash Lights Not Working
This might sound stupid, but when was the last time you replaced the bulbs? It's odd that the lights for some gauges work and some don't.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 12-05-2011, 08:54 PM   #3
Breadman
Breadman's Avatar
I forgot......All bulbs are new.
Old 12-05-2011, 10:16 PM   #4
ozark
Have you checked the headlight switch. It dims and brightens the dash lights maybe the headlight switch is defective or you dimed the dashlights untill they are off? Just a thought.
ozark is offline   Reply With Quote
Old 12-05-2011, 10:33 PM   #5
bikes&bowties
bikes&bowties's Avatar
Or the fuse.,,
bikes&bowties is offline   Reply With Quote
Old 12-05-2011, 10:49 PM   #6
f.monroe
f.monroe's Avatar
Check the tail lamp fuse .The dash lights are on the same fuse if I remember correctly. The idea was to give you a heads up if you have no rear tail lights. It kills the running lights . Not the turn or brake lights.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 12-06-2011, 11:56 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
did you change anyother wires in the cluster plug
may want to take the cluster out and check the grey wire in # 2
for power with a meter to ground
and i've noticed the "board" can shift a bit may not be connecting at the plug?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-06-2011, 02:30 PM   #8
meter swinger
meter swinger's Avatar
Frank
X2 had this happen on mine
meter swinger is offline   Reply With Quote
Old 12-06-2011, 06:34 PM   #9
Breadman
Breadman's Avatar
All fuse's good,headlight switch good,Grey is not hot ?? I changed the board the
other day, but will check alinement.
Old 12-06-2011, 07:01 PM   #10
Breadman
Breadman's Avatar
OK....I run a hot wire to the 2 grey's and the dash light came on.(I know I
can't run a wire like that(Just Testing) So where does the grey wires go
and what to do......Thanks
Old 12-06-2011, 10:45 PM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
the grey wire should be # 2 spot
if there is two one goes to the heater light?
if your grey is in the right spot,try adding a ground to that negative side?
everything else runs ok ,off that negative side of the cluster?
in my 78 all the grounds go down to one just behind the cluster,
what i see in the diagrams, appears to go from the fuse box ,splits to heater and dash lights
http://forum.73-87chevytrucks.com/sm...?topic=11766.0
John
Old 12-07-2011, 01:01 PM   #12
Breadman
Breadman's Avatar
I checked to see if the ground was ok and it was. So I took a thin screwdriver pushed
it down into the #2 slot with the two grey wires and jumped a wire from the green one
to the grey wire...it worked.I took the jumper wire off and the dash lights STAYED ON.
I figured out by accident what was wrong. When I pushed that little screwdriver into
the grey slot the plug must have been loose..Strange things.....O well they are working and I THINK YOU ALL FOR THE HELP...............Breadman
Old 06-07-2013, 11:05 PM   #13
cedens
cedens's Avatar
I have an interesting problem on my 82 went to change the bulbs, except all 5 bulbs are good, the top three do not work the bottom two do.
This was also an attempt to lube the speedo cable.... also on my Oil pressure gauge it reads zero and no or intermittent voltage on the prong.
Now i'm not sure ifs the Pressure sender unit or the gage is bad.
I'm about to make the case for custom autometer possibly in a pro comp!
cedens is offline   Reply With Quote
Old 06-08-2013, 09:08 AM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
I'd pull the cluster back out,check the lube didn't go some where it shouldn't
check the bulbs while out,
wires run under the bulb to socket,
socket/ board /copper paths/and plug has good contact
John
Old 06-08-2013, 11:24 AM   #15
cedens
cedens's Avatar
Thanks, Its still mostly apart, i think its a contact issue, i was able to wiggle one of them to get enough contact to get the bulb to light up as well as the voltage tester.
I just went ahead and ordered new sockets from Classic Chevrolet parts, they are all of 99 Cents a piece, or $1.98 considering i ordered a bulb for each one too.
The bonehead thing i broke the needle on the shift indicator that was a $20 Mistake, also ordered one of those
Old 06-08-2013, 04:18 PM   #16
cedens
cedens's Avatar
Update, pulled the white cluster panel out checked the connections with an ohm meter, cleaned it up a little, plugged the main bulb back in (for th 4x4 light) all came on, just needed the connections cleaned and reset.
always the tough fixes i know, also took the time to put some plastic wire protection over all the wiring harnesses, $11 bag from the local farm/ranch supply place.
