Old 12-05-2011, 09:14 PM   #1
DrtyJack75
Driveline Angle Question-Please Help!
I have a call into Nate Porter but I went and got a angle finder and I'm inpatient.....(if you read this Nate, I havent gave you these numbers yet and not 2nd guessing you)
All numbers are from Transmission going to rear of truck
Trans Angle is .5 down
1st Shaft is 7 up to carrier bearing
2nd Shaft is 4 down to Pinion
Pinion Angle is 4 up to axle
Not sure if I'm explaining this right....but it's basically a W.
Any help would be greatly appreciated!
DrtyJack75 is offline   Reply With Quote
Old 12-05-2011, 11:32 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Driveline Angle Question-Please Help!
Is that 5 down or .5 down?
Also the way you are explaining the rear would equate to a zero degree operating angle, as 4 down on the shaft and 4 up on the pinion would make them perfectly in line. I will still plan on calling you back tomorrow afternoon like we discussed to explain a few things and confirm some of the angles. There will need to be a few changes if your numbers are accurate.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-06-2011, 08:35 AM   #3
DrtyJack75
It's .5, like almost dead straight. Then it's 7 up to the carrier bearing, which leads me to believe the 2" spacer I put in there is to high.
From the Carrier bearing to the front of the pinion is 4 degrees down and then the pinion is 4 degrees up again. So it's a V....
I'm guessing I'm not measuring angles..in the right direction....all measurements are taken front front of truck to rear of truck. Same numbers just different way or saying or reading it I'd think.
Thanks, Talk to you soon Nate!
Last edited by DrtyJack75; 12-06-2011 at 08:37 AM. Reason: (using phone) I copy and pasted something from a post I made to a buddy about our fantasy football league I accident! Hahaha
