![]() Join Date: Apr 2011
Starter wiring
Maybe I'm overthinking this and there's a really simple answer...but here it is
Truck is a 1980 GMC, swap engine is a 5.3L from a '00 Silverado, right now I'm using the stock underhood fuse block from the Silverado to power my engine harness I've gone as far as I can on my own to figure out what I need to connect to the cab in order to get everything turning. Online diagrams aren't helping (even tho they should, maybe I'm just an electrical idiot? ![]() -What wires do I need to connect to the battery/ignition switch/charging circuit? -Is there a specific/separate input that goes into the fuse block for the starter solenoid? I'll probably have more questions as I knock out the final wiring stages, so please bear with me...you guys rulel ![]()
-Steve ![]() 1980 GMC C15 Sierra LWB Dark Carmine Red/Carmine Int Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011) Now: 5.3/4L60E, 2.73 12-bolt open rear |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Starter wiring
The only wires I hooked up between the swap and my original harness was one ign hot and one always hot connection, plus the brake/TCC, VSS and then running a #8 wire from alternator lug to the starter power lug
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: Starter wiring
Huh...I guess I am overthinking it. Now comes the question of which wires are which - I cut all wires going from the cab to the old engine...that was 7 months ago. But I guess that's more of a question for the 73-87 guys...thanks!
