12-05-2011, 11:04 PM | #1 |
trans issue
ok well after swapping the 305 for the 400 everything was good then the other day truck attempted 300 mile journey and suffered the trans still works but is slipping i am now going to attempt to swap the 700r4 for a th400 that has been camped out on a pallet i know i need to change the converter but wat else is going to need to be swaped???
'83 chevy c-10 scottsdale 400 cid 2wd "chelsea" |
12-06-2011, 09:34 AM | #2 |
Robert Olson Transport
Re: trans issue
there is a controller fo the overdrive that needs to be put in
12-08-2011, 10:41 PM | #3 |
Re: trans issue
whys that???
12-08-2011, 11:06 PM | #4 |
Re: trans issue
The flex plate might have a slightly different bolt pattern from the 700 to the th400. I ran in to that problem with my diesel trucks. You will need to run a switch for the kickdown on the Th-400 too.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
12-08-2011, 11:32 PM | #5 |
Re: trans issue
I think old Rusty C10 has it backwards. The TH400 has no overdrive, so that won't be a problem. The only thing you'll have to add really is the electronic kickdown switch.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
12-09-2011, 08:45 AM | #6 |
Re: trans issue
Driveshaft will be different also.
