![]() Join Date: Sep 2011
Question on doors for a '69 GMC
The doors on my '69 GMC are rusted out at the bottoms. I've got holes big enough to stick my fist through and I figure it'd be easier to replace the doors than to try and repair them. Will anything 67-72 fit my '69? Also, is there a difference between Chevy and GMC doors?
Lemme show you something!!
Re: Question on doors for a '69 GMC
Any of the 67-72 doors will fit. However, the 67's have a different latch for the wing windows, the inside handles are different and if I recall the outside door handles have a slightly different mount. The 72's have a screw below the front division bar, on the inside that adds some extra support for the wing window assembly. If you get a matched pair then none of this will matter much.
Hope that helps.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
Thanks for the info. What about GMC vs Chevy doors? Are they the same?
Roadtrip!
![]() Join Date: Feb 2003
They are the same. As mentioned, 67 hardware is slightly different, but won't matter and 72 has different inside latches. Again, no big deal. You will just need to use the 72 door panels or switch your mechanisms. Physically the door shells are basically same.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
