Old 12-06-2011, 04:23 PM   #1
first project
ride height
i am in the begining of installing a four link (chris alstons) in a 1980 chevy swb I am wondering what determines the ride height in my directions I want my diff centerline 15 1/2 inches but how do I know where to set the frame for height
first project is offline   Reply With Quote
Old 12-07-2011, 01:39 PM   #2
made2drag
made2drag's Avatar
Re: ride height
that's a little vague. i would say that you should set your ride height after you have your truck all the way lowered. in otherwords, if you are laying out, then you need to have a ride hieght of about 3 or 4 inches if you think that is what you need. if your not laying out and your axle is touching your frame or notch then i would set the ride hieght for 2 inches of clearance between the frame and the axle. if im way off base on this answer or you already know this....sorry
made2drag is offline   Reply With Quote
Old 12-07-2011, 06:19 PM   #3
first project
Re: ride height
thanks that helps me I dont explaine very well what I am asking I am stuck because I do not no how far off the ground my frame should be when I put the front cross member on my instructions say that I want 6" from the ground to the bottem of the bracket that the rod goes to and I want that rod to be straight, to do that I have to lower the frame on to the diff well into the knotch that I cut or I have to install a shim between the frame and the cross member
Old 12-08-2011, 10:15 AM   #4
made2drag
made2drag's Avatar
Re: ride height
hmmm....i wish i could help on that, but looks like you need someone with experience. maybe someone who has done the crossmember and 4 link will chime in. or find a build thread where someone has done it and send them a PM? good luck
Old 12-08-2011, 10:17 AM   #5
made2drag
made2drag's Avatar
Re: ride height
it would help if you posted a pic...a lot of us need a visual to be able to help...at least i do
Old 12-08-2011, 11:43 AM   #6
first project
Re: ride height
thanks for your help when I get home I will post some pics
