Old 12-06-2011, 05:06 PM   #1
AD51
AD51's Avatar
What kind of motor mounts work best?
Could some of you chime in on motor mounts. What is the best way to mount a small block. Ive seen where most everybody tries to place the engine where the distributor is a couple inches from the firewall. But are you all making your own mounts or is there a mount to buy that works well? Thanks
AD51 is offline   Reply With Quote
Old 12-06-2011, 05:52 PM   #2
55metalmonkey
Re: What kind of motor mounts work best?
LMC and a few others sell SBC conversion mounts for AD and TF trucks. As for how well they work and how easy it is I'm not sure. I went a completely different route with mine (subframe)
55metalmonkey is offline   Reply With Quote
Old 12-06-2011, 06:21 PM   #3
parkwood
parkwood's Avatar
On the '51 suburban i bought some from TCI and on the '57 i cut out and made my own...
parkwood is offline   Reply With Quote
Old 12-06-2011, 06:47 PM   #4
AD51
AD51's Avatar
Im sorry, I forgot to include that I am using an S10 frame.
Old 12-06-2011, 06:51 PM   #5
parkwood
parkwood's Avatar
You can still set the motor up where you want it, level, clear the fire wall, as low or as high as you need it and fab your own from cardboard and the cut them out of steel and weld them in.. I'm have not worked with clips to know what is best, sorry..
