Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-06-2011, 06:28 PM   #1
chevymotocross
chevymotocross's Avatar
92 S10 Blazer 4x4 loose column shift lever
Now that the crappy weather is here and my C10 is parked, I have been driving my 92 s10 blazer 4x4. The column shift lever was always somewhat crappy, but now I'm having trouble getting it to hold in park. Fine going in R N OD D 2 1
What should I be looking at for replacement? And are there any write-ups for it?
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 12-06-2011, 09:54 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: 92 S10 Blazer 4x4 loose column shift lever
I would first check to see if any of the linkage between column and trans is loose or worn. IIRC there is a rubber grommet at the end of column arm where the shift rod attaches. is this sloppy?
then if this all checks OK I would make sure the end of shift tube in column is tight and not loose.
finally I would see if the shift arm fits good into the column and the pin is tight in both the arm and lower bowl.
there is also a slim chance you have a problem with the shift gate inside column.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 12-06-2011, 10:59 PM   #3
chevymotocross
Thank you, I will check at those locations
