few pics of my new brake booster
this has been a fun and frustrating project but its finally done. this is the before and after
Junior Member
Re: few pics of my new brake booster
Please, please, Give the details on how you went about adding the hydro boost.. Looks like it's going to be a spring time project for me... Also looks like no captin fab bracket, right?
Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." |
Nice looking setup...
Is there a reason why this same type of master couldn't be used in a non-power drum/drum set up providing it has a 1" bore? |
here is a picture of the bracket kit, hydroboost unit from junk yard all cleaned up and with bracket attached. hydroboost is from a chevy astro van
the bracket mounts the hydroboost upside down which is great for routing the hoses and it still works just fine
blackedoutharley, i dont see why you would'nt be able to use that same type master cylinder in a non power application
Junior Member
Where did you get the bracket kit?
fastrucken, picked it up from a company called talon hydraulics
got any pictures of how you route the hoses, to the power steering pump and gearbox? i'll be doing this when i get the hoses and pump!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
I'm very interested in the way you installed this system. Please give use more details. I just picked up the same booster.
After installing the booster how do the brakes feel. |
![]() Join Date: Feb 2011
Subscrib-ed...Very Kool!
MusicMan70 1961 GMC Suburban |
60-66 Nut
![]() ![]() Join Date: Mar 2007
If you are wanting a dual reservior drum/drum master, all you need is one for a '67-'70 pickup with manual brakes.
#13 |
But I like the looks of this one! LOL
#14 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
subscribed
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#15 |
Junior Member
![]() Join Date: Sep 2011
Cool project!!!! I can't wait to see how you routed the lines. When I get my truck to the point I will most likely add hydro boost as well.
#16 |
here are a few more pics of the routing. there are a few ways to go with this but i tried to keep it as simple as possible
#17 |
66farmer, the difference is like night and day, the steering is unaffected, they are a little touchy but i like it that way and best of all there are no worries about not having enough vacuum
#18 | |
1. What steering pump did you use. 2. How did you attach the booster rod to the brake pedal. 3. The Astro booster I have had a reservoir did you plug that off. 4. Were do the lines go. (Like pump pressure to inside booster port and so on) 5. Do you have a phone number or web address for company that you got the booster bracket I could't find it. Thanks for posting this you did a verry clean job. |
#19 | |
#20 | |
#21 | |
#22 |
![]() Join Date: Aug 2005
This is FAQ material when it's run its course. Great info, thx!
#23 |
Senior Enthusiast
Outstanding, nice job! Thanks for sharing all the details.
#24 | |
#25 | |
![]() Quote:
