Ordering coilvers today
I am going to order coilovers today. But I can't decide what spring rate to order.
I am thinking 200 pounds per inch. I am going to get QA1 aluma matics. They are going on a 52 GMC with a triangulated 4 linked 10 bolt out of a 76 Monty Carlo. I will be putting a 20 gallon gas tank behind the rear end. I know ride stiffness is a personal preference. I want to be a bit on the stiff side for cornering stability. |
Re: Ordering coilvers today
what are you guys running?
i am running Aldan coilovers but than again i have a vette rear suspension -w/ a 19 gallon fuel tank in back - same spring rate i think .
If you call QA-1 they should be able to recommend a spring rate for your needs.
My rear coil overs have 250# springs but it's not on the road so I can't comment on them. Kim |
I'm in a similar situation as Kim of having 250lb springs and not knowing how they feel yet. Don't forget about correction factors due to the angle of how you mount them.
looks nice. is that part of a watts link on the floor?
Mark, did you order the coilovers yet? What did you end up ordering?
