12-07-2011, 12:08 PM | #1 |
Restoring it $200 at a time...
Could I have boiled brake juice?
So the brakes went from "getting a little soft" to "really have to plan ahead" because the rear chamber on the MC was nearly empty. I've been over the lines from front to back and don't find any liquid leaks anywhere. No seeps at the bleeders or wheel cylinders either. I did see that the rear supply line has been laying against a header tube. Could there be enough heat transfer there to cook the fluid out?
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
12-07-2011, 12:14 PM | #2 |
Quit if it's not FUN!!!
Re: Could I have boiled brake juice?
I just got thru dealing with almost the same issue. "Fluid level dropping, no visible leaks. Found that M/C was leaking out the back (old dry, hard boot). Carpet pad was soaked. Replaced M/C and boot. No more lost fluid. P.S., don't overfill M/C, it can actually push fluid out the top, around the cover.
12-07-2011, 01:00 PM | #3 |
Can leaking into the vacuum booster without being seen.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
12-07-2011, 01:01 PM | #4 |
I've seen m/c's leakinto the booster and you can't find till the booster fills over half the way up. Pull the m/c mounting bolts and look for wetness ther. brake fluid has a fairly high boiling point I don't recall off hand what it is but I think it would be higher than a header transfer would do unless it is right at the exhuast port
12-07-2011, 03:36 PM | #5 |
No booster to contend with, but I will see what the MC looks like when it's demounted.
12-07-2011, 07:25 PM | #6 |
its all about the +6 inches
No booster... NO need to remove it to look. Just look inder the dash where the brake push rod goes through the firewall.
You'll want to move that brake line at least an inch from the header. I personally try for at least two inches. Posted via Mobile Device |
12-07-2011, 08:32 PM | #7 |
Well crap. I was doing well to get it 1/4" off the tube.
12-07-2011, 08:55 PM | #8 |
Has the brake line been routed next to the header for a long time, and has the problem just started? If so, I don't think its a heat issue if its been working OK for this long. Sounds like a leak or really worn or broken brake linings. When the shoes are really toast, the brake pistons need all the fluid they can get to spread the shoes enough to contact the drum. This can empty the MC reservoir.
If you just installed the headers next to the brake line, then maybe heat is the culprit, but I doubt it. Good luck. |
12-07-2011, 11:41 PM | #9 |
Brake lines have been near the header for awhile. I was kind of grasping at straws there. Worn shoes would make sense-thanks for a new path to check out.
