Old 12-07-2011, 03:36 PM   #1
antG49-05
antG49-05's Avatar
NEW to the board, need some advice
whats up im new to the forums i see alot of you guys got some real nice rides. real quick info on what i got im working on a 1949 chevy 3100 delux cab. and i also have an 05 chevy reg cab. the problem i have is that my 05 has a ROUGH ride its lowered in the rear i did not lower it i bought the truck with it already lowered. it bottoms out over any and all bumps. just want to know what options i got to fix this problem and have a smooth ride. thanks.[IMG][/IMG]
antG49-05 is offline   Reply With Quote
Old 12-07-2011, 10:10 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: NEW to the board, need some advice
Welcome! I'd say a C-notch should get you some movement back, or you could bring the back up a little if you prefer.
http://www.ebay.com/itm/99-00-CHEVRO...-/160626480304
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-07-2011, 10:45 PM   #3
antG49-05
antG49-05's Avatar
thanks, i highly appreciate the info
Old 12-08-2011, 09:20 PM   #4
k5hart
k5hart's Avatar
Do you know how they dropped it? It looks like a 6' drop but with the axle still under the springs they either put on dropped springs, removed some leafs (not a great idea), or (hopefully not) heated them so they would collapse. Is it bouncy or just bottoming out all the time? It definitely looks like a notch is needed. You could also get shock relocators to try and get the shocks back to a good operating angle. Drop shocks will help also. I have Belltech Street Performance shocks on mine and happy with them.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 12-08-2011, 09:59 PM   #5
antG49-05
antG49-05's Avatar
thats my other problem i have no idea how they did it. its more bottoming out than bouncy.
Old 12-08-2011, 10:23 PM   #6
usmcchevy
usmcchevy's Avatar
Post some pics of the spring hangers, shackles and the springs. We should be able to figure it out from that
Build thread
LSx Swap FAQ index
Old 12-09-2011, 03:08 PM   #7
biggsteve97
wow. well no matter how it was lowered unless you raise it back up you will have to c-notch the frame to get any kind a ride now. it was definitely dropped way too far to not have the c-notch
biggsteve97 is offline   Reply With Quote
Old 12-10-2011, 08:39 PM   #8
Boog
laying low
Boog's Avatar
Do you know if the axle is actually contacting the bump stops or frame or are maybe the shocks themselves bottoming out? That will narrow down what you need to correct the problem.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-10-2011, 09:06 PM   #9
k5hart
k5hart's Avatar
That low. I can guarantee your hitting the bump stop. I wouldn't doubt the shocks are at their limit too if they are stock. The first thing I would do is notch it, then see how it rides and go from there.
