Old 12-07-2011, 05:01 PM   #1
jsw72c10
big block upgrade
i have a 72c10 that had a factory small block.thought about going with a 454 with th350 or 400.just wondering how many changes i'll have to make. any help would be appreciated.
jsw72c10 is offline   Reply With Quote
Old 12-07-2011, 09:25 PM   #2
Willie496
Re: big block upgrade
We bolted a 454 into a 1970 gmc 1/2 ton. Our truck has a 4 speed tranny the only mod we had to make were to the header on the drivers side too clear the clutch shaft. It bolted right in, including using the small block frame mounts.
1969 GMC 4x4, 4 speed, 350 Fleet Side in progress.
1969 Camaro SS 427 Cortez Silver. owner since 1974
1964 Chevelle 4 Door, 427 Big block,Turbo 400
1/4 Mile 10.52 @ 125.85 mph. 1.39.1 60'
1982 Crew Cab 3+3, 2WD 3.21 Locker, 468/4 speed
1969 C30 4 speed (IL6) future build.
Willie496 is offline   Reply With Quote
Old 12-08-2011, 01:23 AM   #3
Shyguy
Junior Member
Shyguy's Avatar
We put a '74 in front of a SM-465 in my '71 lwb stepper using the engine mounts that came with the 454 without a problem other than we had to modify the clutch bracket on the frame.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 12-08-2011, 08:16 AM   #4
MARKDTN
Exhaust manifolds or headers, cooling, pulleys and brackets if you don't have them, mounts, 454 is externally balanced so would need a different flexplate or flywheel. It can add up fast.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-08-2011, 10:12 PM   #5
trkfrk
trkfrk's Avatar
Keep in mind the additional weight will effect your ride height.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 12-08-2011, 11:13 PM   #6
von guido
von guido's Avatar
what he said^^^^ i had lowering springs and a small block. I put a big block in and the truck settled another 2 inches,destroying my bumstops in the process
officer,we weren't racing.. he was merely pacing me.
von guido is offline   Reply With Quote
