Old 12-07-2011, 05:08 PM   #1
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Mystery Pieces, please help me identify!
Hi there;
wondering what these two brackets are from....I definitely took them off either a 4L80E tranny or LQ9 motor.
Also wonding if this mystery line circled in red is a fuel return line on my motor, again its a LQ9....but I thought my motor didn't have a fuel return line.
Any help is very much appreciated!
Thanks!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 12-07-2011, 06:29 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Mystery Pieces, please help me identify!
The line I believe is one that sends the unspent fuel vapors back to the vapor canister. you wont need it but you should plug the spot on your intake.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-07-2011, 09:03 PM   #3
adub024
adub024's Avatar
The brackets bolt to the power steering pump....Here is a picture of them on a lm7 should be the same...This is the best pic i had hope this helps
Ryan
adub024 is offline   Reply With Quote
Old 12-07-2011, 09:05 PM   #4
adub024
adub024's Avatar
If i remember right the bottom one was holding the part of the wiring harness that ran under the engine. The back one is a support to the block
Old 12-07-2011, 10:47 PM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
The line/solenoid is your EVAP emissions. Its there to basically suck any vapors out of the charcoal canister. You can delete it and plug the hole in you intake with a pipe thread plug.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-08-2011, 01:36 AM   #6
Gordonr1973
Home Built '87
Thanks for the info guys!
I will look it over tomorrow and try to fit the brackets on if needed and will see what thread size that plug might be.
Thanks again!
Gordon
Old 12-08-2011, 03:42 PM   #7
mcbassin
Still Learning
mcbassin's Avatar
You know what size plug you used? I've seen or read somewhere about a block off plate?
mcbassin is offline   Reply With Quote
Old 12-08-2011, 06:46 PM   #8
usmcchevy
usmcchevy's Avatar
1/4" NPT....I think Its been too long and I cant find the receipt. I'm not aware of a block off for the EVAP. I know there are ones for EGR.
Build thread
LSx Swap FAQ index
Old 01-27-2012, 12:38 PM   #9
Gordonr1973
Home Built '87
I finally got around to looking at this last night, there is a plug already there that is held in by a bolt beside it. When I pulled the plug it didn't have any threads to screw a real NPT into...
Would I have to tap / die it in? What did other people do?
Gordon
Old 01-27-2012, 02:23 PM   #10
OldCreek
OldCreek's Avatar
I agree with all of the above. I believe I left the evap valve in there and just put a rubber nipple cap over it.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 01-27-2012, 02:48 PM   #11
usmcchevy
usmcchevy's Avatar
I let the plug cut its own threads.
Build thread
LSx Swap FAQ index
Old 01-27-2012, 03:03 PM   #12
ls1nova71
ls1nova71's Avatar
Unless you're really tight on hood clearance just leave it in there. No need to cap it off, the valve is normally closed.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-27-2012, 08:01 PM   #13
Gordonr1973
Home Built '87
Thanks, that makes more sense.
Next question, what did you guys do with this line?? I think it is a vapor return line back into the head??
Gordon
Old 01-27-2012, 08:28 PM   #14
mooseknuckles
mooseknuckles's Avatar
thats the vaccum line for the brake booster.
mooseknuckles is offline   Reply With Quote
Old 01-27-2012, 08:43 PM   #15
Gordonr1973
Home Built '87
Okay, that makes sense too!
Thanks guys, I actually might put my truck together within the next decade!! :-)
Gordon
Old 01-28-2012, 12:08 PM   #16
Gordonr1973
Home Built '87
So, here's my absolute last question on the subject....where does the vacuum tube connect to on the engine to supply vaccuum to the controls for the heater / A/c / defrost etc etc units?
Could this be it or is there another place?
I've been searching on the forum for the answer to this for a while without finding a clear explanation where the vaccuum draw is on a LS motor.
Gordon
Old 01-28-2012, 01:15 PM   #17
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
found this off of an LS1 swap into a z32, looks like the port on the back of the intake mani goes to the hvac controls.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-28-2012, 01:22 PM   #18
ls1nova71
ls1nova71's Avatar
On the passenger side of the intake about 5 inches from the rear you will see a round thing that has what looks like a vacuum nipple in it, it has a little tab on the end of it that's about 1/4 inch, break that off and the fitting is there and has tow tabs that grab the hose to keep it from falling off. I can post pics when i get home if you need them, but you should see it.
Old 01-28-2012, 01:26 PM   #19
ls1nova71
ls1nova71's Avatar
What I just posted is for a truck intake. The pic BR3W posted is a car intake.
Old 01-28-2012, 04:39 PM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
^correct, that diagram was the only thing I could find lol, my LQ4 repair manual doesn't have a vacuum diagram, wtf.
Old 01-28-2012, 05:20 PM   #21
ls1nova71
ls1nova71's Avatar
Probably doesn't have a diagram because there are no vacuum lines on some trucks. If it's returnless fuel rail it wont have a vacuum line to the fuel pressure regulator, and if it had hydroboost then no vacuum power brake hose. What others are there? All HVAC are electric servos now too so nothing there. We've come a long way since the 80's when there was about 6 miles of vacuum hose on a car! Lol
Old 01-28-2012, 09:02 PM   #22
Gordonr1973
Home Built '87
Thanks guys I found it!!!
GM loved using vacuum hose!
Gordon
