Old 12-07-2011, 11:04 PM   #1
1972RedNeck
1972RedNeck's Avatar
Calling To All Those That Have A 700R4
I have a 700R4 in my '72 K2500. The shift indicator points a ways past park when in park. When in reverse it reads park. When in second, it reads first and in first it reads a ways past first on the indicator. What do I need to do to solve this?
I need to lessen the amount of travel it has, right? How?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-07-2011, 11:59 PM   #2
chevy88
chevy88's Avatar
Re: Calling To All Those That Have A 700R4
I do not have a 700R4 installed but I would make one of the pivoting arms shorter, either on shift column or trans shifting arm this should take care of the over travel.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 12-08-2011, 12:13 AM   #3
Indyuke
chevy88 is right. Pictured below is the arm coming off the steering column. This is where I made most of my adjustments when I put in my 700r4. Keep in mind that the 700r4 has 7 detents to the t350 or t400's 6 detents.
700r4: Park, Reverse, Neutral, Overdrive, Drive, 2nd, 1st
t350: Park, Reverse, Neutral, Drive, 2nd, 1st
When you have it adjusted right, and with the old indicator lens in place, the shift indicator will fall outside the lens when you put it into 1st unless you get an indicator lens made for an O/D trans. All the others will line up though.
Indyuke is offline   Reply With Quote
Old 12-08-2011, 01:01 AM   #4
SactoJim
SactoJim's Avatar
Lokar makes a shift arm that I put on mine and with a little tweaking, I got it to line up well with the overdrive bezel indicator on my column.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 12-08-2011, 10:28 AM   #5
Curt's_72
Curt's_72's Avatar
Another issue I incountered was the backup lights coming on at the wrong time. I adjusted by tweaking the switch at the base of the column inside the cab and slightly rotating the entire shaft to get them correct in reverse. These adjustments were in conjunction with the ones on the shifter rod discussed above.
Curt's_72 is offline   Reply With Quote
Old 12-08-2011, 08:43 PM   #6
1972RedNeck
I am pretty sure the lens for a 700R4 is no wider than original. The positions are just spaced closer. If I line park up now, it will only go into 2nd.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 12-08-2011, 08:44 PM   #7
1972RedNeck
Originally Posted by Curt's_72 View Post
Another issue I encountered was the backup lights coming on at the wrong time. I adjusted by tweaking the switch at the base of the column inside the cab and slightly rotating the entire shaft to get them correct in reverse. These adjustments were in conjunction with the ones on the shifter rod discussed above.
I also have this problem. I can't get it to start and have the reverse lights work. I have to choose between the two (very simple choice).
Where can I get one of these?
Also, where can I get an overdrive lens for my non-tilt column?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 12-08-2011, 09:12 PM   #8
k5hart
k5hart's Avatar
This has been my experience. Never had a problem.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 12-08-2011, 09:28 PM   #9
72GMCK-2500
72GMCK-2500's Avatar
I have a 700r4 in my 88 caprice 9c1 cop car and the linkage was so off when i bought it the back up lights came on when it was in park and went off in reverse and so-on. What i did was tighten up the linkage from the column to the tranny, new spring and cotter pins did the trick for me, may work for you, i have the same truck as you 72 GMC k2500 but minus the 700r4 and minus the air condition!
1947 Chev 3600, 454,th350,9"ford tubbed (Pop's ride)
1965 GMC 1000 305E V6, Powerglide. GONE
1972 GMC K-2500 350, 4 speed, 229,000 miles
1988 Chevrolet Caprice 9C1 Ex cop car, 350, 700r4.
1997 Ford F-350 4x4 XLT (The Hauler) 7.3 diesel.
RUST NEVER SLEEPS
72GMCK-2500 is offline   Reply With Quote
Old 12-08-2011, 09:49 PM   #10
jocko
jocko's Avatar
item # 32-7235 for 700R4
http://www.lmctruck.com/icatalog/cb/full.aspx?page=126
Old 12-08-2011, 10:42 PM   #11
PHAT TONY
PHAT TONY's Avatar
I set mine up so it doesn't hit 1st, no biggy, reverse lights work and it's right from P-D at least.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 12-08-2011, 11:42 PM   #12
1972RedNeck
I need one for non-tilt.
I would like to be able to use first (I have no idea why). I will look into shortening some part of the linkage.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 12-08-2011, 11:45 PM   #13
jocko
jocko's Avatar
Ah, sorry, that's what I was afraid of. Might be worth calling LMC and see if they can get in touch with the mfgr.
I don't know what the difference between a tilt/non-tilt lens would be, but there must be a difference, because that is the only combo (non-tilt 700R4) they DON'T list. Odd.
I guess in order to line up your point, you could make your long-awaited transition to a tilt column earlier than planned....
Old 12-09-2011, 02:53 PM   #14
1972RedNeck
I already tried a tilt one. They aren't even close. I'd rather have a tach and vac before tilt. I am pretty sure I saw a lens for a non tilt somewhere. I just can't find it.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 12-10-2011, 12:58 PM   #15
classicchev
classicchev's Avatar
I have had a few in my trucks. Usually loose 1st gear, just to get the adjustments right. Always altered the linkage also, legnthen and bend.
67- 72 Parts collecter
classicchev is offline   Reply With Quote
