12-08-2011, 02:21 AM | #1 |
6 bolt rotors on 2wd spindles? can it be done?
hello
planning my build on a 81-87 chevy 2wd with 5 bolt wheels.. looking to swap to the 6 bolt front and rear for two reasons.. one i can use a 14 bolt 9.5" 6 bolt rear axle, and i can put newer style 6 bolt gm wheels on the truck. has anyone ever put 6 lug rotors on the front... excuse me if this is a common thing, but i would appreciate a point in the right direction... will a 67-72 2wd 6 bolt front rotor fit maybe? Let me know what you think |
12-08-2011, 01:18 PM | #2 |
Re: 6 bolt rotors on 2wd spindles? can it be done?
Aftermarket disc brake swap rotors come in both a 5 or 6-lug pattern. You just need the 6-lug rotors.
