Old 12-08-2011, 11:34 AM   #1
steve'62
steve'62's Avatar
steering wheel questions
What wheels will fit my 62?
I purchased a 1965 impala steering wheel ebay thinking it would go right on but it didnt. I also see all kinds of older belair steering wheels that i lie but know if they will go right on. A little help would be great guys!
steve'62 is offline   Reply With Quote
Old 12-08-2011, 11:42 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: steering wheel questions
Do you have an aftermarket steering column? Most of the steering wheels of that era had the same spline spec.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-08-2011, 11:53 AM   #3
steve'62
steve'62's Avatar
Its not aftermarket, the spline is the same but length of that splined metal part is too long and wont let it go down far enough. I sticks up to high and if I force it, then it pushes on the turn signal and they wont work.
Old 12-08-2011, 01:49 PM   #4
X24
Is that with the cancel cam?
Cuz if it is I think you can shave it.
X24
1964 chevy c10 step side
230ci straight six
Auto power glide
X24 is offline   Reply With Quote
Old 12-08-2011, 03:25 PM   #5
steve'62
steve'62's Avatar
It's without it
Old 01-06-2012, 11:52 AM   #6
NCD1966
NCD1966's Avatar
I too have a 1966 impala steering wheel to be put on my 66 stepper. I haven't removed my current wheel to see if it will work yet.
steve'62 did you get yours to work? btw I have the factory column with the 3 speed column shift
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 01-07-2012, 09:51 AM   #7
Blue Heeler
Blue Heeler's Avatar
you will have to shave the turn signal housing a little more than 1/8 of an inch and just keep checking, i found out the hard way when it started grinding the back of my wheel after i painted it. i was pissed!!
Blue Heeler is offline   Reply With Quote
Old 01-07-2012, 10:01 AM   #8
NCD1966
NCD1966's Avatar
Thanks Blue Heeler; that doesnt sound like too much to take off. Will see
Old 01-07-2012, 10:11 PM   #9
Blue Heeler
No prob.
