Old 12-08-2011, 12:49 PM   #1
CHEVY THUNDER 90
03 Silverado axle swap
Hello all! I am an active duty soldier just returning from Iraq to my baby I left for a year. My 2003 Chevy silverado SCSB z71 4x4 lifted 4inches on 35s (With carefully cranked t-bars and added leafs) Does anyone have any suggestions for fairly easy axle upgrades? It currently has the 8.6 posi 10 bolts with 3.73s. I know I need to address gear ratios and hoping to do that also. I am a tank mechanic with mechanical knowlege..just need ideas. Thanks for the help!
CHEVY THUNDER 90 is offline   Reply With Quote
Old 12-08-2011, 06:55 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 03 Silverado axle swap
Its always good to be home!
Can't help much on the axle, maybe a 6 lug 14-bolt.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-08-2011, 07:01 PM   #3
CHEVY THUNDER 90
Thanks man its good to be home. Do you know what trucks the 6 lug 14 bolt came on?
Old 12-08-2011, 07:09 PM   #4
usmcchevy
usmcchevy's Avatar
Application I had in mind would be out of a 04+ Vortec High Output(VHO) or V-Max truck. Pretty sure they only came with drum brake though.
Build thread
LSx Swap FAQ index
Old 12-10-2011, 12:42 PM   #5
CHEVY THUNDER 90
I wonder if the make adapters from the 8 lug 14 bolts to convert them to 6lug? I know the 03 2500HDs are disc which would make life easier for me.
Old 12-17-2011, 11:22 PM   #6
1978steven
1978steven's Avatar
You could do a 14 bolt SF swap out of a OBS 4X4, that would swap right in after some minor mods. Depending on what you use the truck for you could just re-gear front and rear for the added tire size and rolling mass. If you are mainly street, and don't get too crazy off road the 10 bolt will hold up just fine. My Z has 6 inch pro comp, 3 inch body lift, and running 37X13.5 R20 Nitto Mud Grapplers with the 10 bolt re-geared to 4.88 with a detroit true trac. My truck is my daily driver and off road toy, been running just fine with no issues for going on 4 years. The main thing is to ditch the g-80 limited slip, g-80 failures are pretty common in the 10 bolts....
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
