Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-08-2011, 01:17 PM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
99 S-10 V6 OBD port not working
I have a CEL and plugged in my low buck scanner to pull a code. THe display on the scanner did nothing. This is a working scanner, I tried it on my Tahoe with no issues.
I found info about it getting power from the cig lighter, but the lighter is working. Anything else I can check?
Thanks for your help!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-08-2011, 08:03 PM   #2
truckdude239
truckdude239's Avatar
Re: 99 S-10 V6 OBD port not working
thast it unless theres a sort in the wiring or the computer is dead
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-08-2011, 08:04 PM   #3
truckdude239
normally its the cig fuse check it just to be safe
David fuller
2000 Tahoe 5.3l 378
Old 12-09-2011, 09:42 AM   #4
61_FL_Apache
Who Me?
Cig fuse is fine and the truck runs normal so the ECM is not dead. It may be tied to another fuse under the hood. I will need to check one by one.
Steve
2001 Blazer 4D 2WD
Old 12-09-2011, 05:33 PM   #5
truckdude239
obd 2 port is run on the cigar fuse in those trucks you can use a test light to see if one pin the plug should be hot all the time that's the power for the port. ecm can be dead and still run fine though it is unlikely that the ecm is dead
David fuller
2000 Tahoe 5.3l 378
