Old 12-08-2011, 02:19 PM   #1
vegas80step
vegas80step's Avatar
Ok were are the guys that speak "rim" will they fit?
I really didn't want to post a "will these fit on my truck post"
BUT... I am...
I get the hole +/- offset thing and back spacing... I found the chart and the diagrams... but the rims I'm looking at list things like +18 or -34 (which I assume is in MM) but I don't have my truck. So really it does me no good.
I'm thinking about running American Racing "Nova" (VN701)
Front 18x9 (offset options +24, +35, +45)
Back 20x10 (offset options +18, +35) or a 20x11 +18
on my 1980 stepside, the truck will be bagged with a small C notch. no bed mods. no fender mods.
I'm not trying to lay it out, just as low as it will set and want to keep the tires under my fenders.
Any input? which offset? Anyone running these rims? any input on tire size? I'd like to add a little more rubber on back.
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 12-08-2011, 02:27 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Ok were are the guys that speak "rim" will they fit?
The 18x9's need a 6" BS. (+25mm offset)
The 20x10s need at least a 5.5" BS. (0mm offset)
Looks like you could run a +24mm offset up front,... but the rear +18mm offset is going to require you to run spacers.
(or tub the bedside)
Remember,... the stepside beds don't have quite as much room at the fleetside beds.
Keith
Convert to disc brakes.
Old 12-08-2011, 02:38 PM   #3
vegas80step
Thakns for the info... So do you think the 20x10 w/space will tuck?
Old 12-08-2011, 02:46 PM   #4
lolife99
lolife99's Avatar
Yes.
A +18mm on a 10" wide rim is about a 6.25" BS.
You need about a 5.5" BS.
(that's only a 3/4" spacer,... which I don't think anyone makes)
Maybe a 1" spacer would work.
Like I also say,... don't take my word for it.
Break out your tape measure and measure for yourself.
Here's member hot trux' '85 stepside.
These are 20x9.5's with a 5" BS and a 295/40-20 tire on the back.
Keith
Old 12-08-2011, 03:59 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Keith... didn't hot trux need to run a rear spacer? Or am I mistaken?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-08-2011, 04:02 PM   #6
lolife99
lolife99's Avatar
You are not mistaken.
He listened to someone that told him he needed a 6" BS.
(he has a 1" spacer which equals a 5" BS)
Like I said,... measure for yourself!
Keith
Old 12-08-2011, 04:05 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I thought this might be a good learning point for others prior to ordering their wheels.
Measure and when you think you've got the right numbers, do it two more times. (If not more...)
-Nate
Old 12-08-2011, 06:05 PM   #8
vegas80step
Yes.
Great looking truck... thats pretty much the look I'm going for in rim/tire size..
thanks for the info, helps alot... I found these http://www.jegs.com/i/JEGS/555/65053/10002/-1?CT=999
No way buddy... I'll be like but, but the guy said they would fit....
naw just blame keith.... lol
Old 12-08-2011, 10:35 PM   #9
Stepper562
Stepper562's Avatar
Spacer time.....
Stepper562 is offline   Reply With Quote
Old 12-09-2011, 01:57 AM   #10
lolife99
lolife99's Avatar
You really need to use this type of wheel spacer.
http://www.ezaccessory.com/Wheel_Ada...5500-5500p.htm
Keith
Old 12-09-2011, 10:11 PM   #11
vegas80step
So now you want me to worry about my rims staying on my truck??
Man, I can see you sweat the small details..... lol
(Thanks for all the great info buddy)
Old 12-09-2011, 11:44 PM   #12
muthstryker
muthstryker's Avatar
You could always have a 3/4" wheel spacer made that was hub and wheel centric through these guys www.motorsport-tech.com I would install longer studs though. Don't buy cheap adapters, you get what you pay for. And your life would be depending on that cheap product holding your wheels on.
Matt
muthstryker is offline   Reply With Quote
Old 12-10-2011, 01:25 AM   #13
primrrd
primrrd's Avatar
good info here.
can you explain why the spacers you posted are bad- and where to buy better.
Lo life- with 20's on front- what is the average best backspace?
primrrd is offline   Reply With Quote
Old 12-10-2011, 01:42 AM   #14
muthstryker
The link that lolife posted, the problem with those is they are not wheel and hub centric. Its important that the wheel be hubcentric so you wont have vibration issues. Basically you would just be relying on the lugs to keep the wheels centered, if you hit a big enough pot hole the wheel can become off center on the lugs. Plus the cheaper Chinese have cracked before.
The link I posted (www.motorsport-tech.com) Can make your adapters/spacers both hub and wheel centric. They will cost more but its worth it for piece of mind. Plus they wont break on you.
Matt
Old 12-10-2011, 01:53 AM   #15
lolife99
lolife99's Avatar
Originally Posted by primrrd View Post
good info here.
Most squarebody truck owners use what the industry makes.
20x8.5 with a 5.25" BS is a standard size for companies like Coys, and American Racing.
On static dropped trucks,... I like a little more backspacing, (5.5" BS) and bagged trucks I like 5.75" backspacing.
If your truck has a Dropmember or a set of a-arms that narrow the front track width,... you have to re-think these numbers.
Wider front rims make the backspace numbers different yet.
It's all a matter of personal preference, when it comes to how far you "tuck" the wheel.
Keith
Old 12-10-2011, 09:00 AM   #16
1LowToy
Nice wheel I won't comment on the spacing because when I shop for plumbing it takes 5 trips to the hardware store for two fittings.
1LowToy is offline   Reply With Quote
