Old 12-08-2011, 08:41 PM   #1
junksaver
Drilling out an Ignition Switch
I just wanted to post my experience with an ignition switch and no key. I just picked up a 67 stepside this past weekend with no key. I pulled out the passenger side lock cylinder to have a key made for it. Between pulling the cylinder, trying to find a locksmith and going to get the key made, I spent 2 1/2 hours. The locksmith made a key, but it wouldn't turn the cylinder. I'm not sure if he knew what he was doing, but I gave him $5 for his trouble. I brought the key back and it wouldn't work for the ignition either. I decided to drill the ignition out. If you are going to do this you better have patience. It took 1 1/2 hours. I had to drill 2 holes. If you look at the pictures I drilled out the center 1st starting with smaller bits and working my way up to 7/16". It still wouldn't come out. I drilled another hole directly below that one where the pins are located in the cylinder. I kept drilling with larger bits till the 2 holes connected. I was then able to put a paper clip in the small hole and twist it out with a screwdriver. If I had to do it over I would start by drilling a small hole in the bottom directly below where the key goes in. If you start there and work your way up to larger bits I think it would come out quicker.
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 12-08-2011, 08:54 PM   #2
dmwphoto
dmwphoto's Avatar
Re: Drilling out an Ignition Switch
how easy would it have been if you had a working key?
dmwphoto is offline   Reply With Quote
Old 12-08-2011, 09:05 PM   #3
black_sheep454
I have to do this to my swb, the guy I bought it from lost the key.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 12-08-2011, 09:55 PM   #4
Ackattack
Ackattack's Avatar
Here is the funny thing about my experience the other day. Both my 68 and 69 keys are on the same key chain. I replaced the ignition/door key cylinders in both of them as part of each build. I have a little tag on the 68's key, so I can tell them apart.
Well the other day I stuck the 68's key into the 69 without thinking about it and turned the key and it started. The ignition kinda hung in the start position for a little bit (1/2) and thats what made me realize it was the wrong key. Usually, especially the original ignition cylinders, are so sloppy you can use a screw diver to start them (or in my 69
s case when I got it, an old steak knife....hence why I replaced it )
Ackattack is offline   Reply With Quote
Old 12-08-2011, 10:13 PM   #5
blkcorvair
blkcorvair's Avatar
You have to find an old time locksmith to handle them old keys. Alot of the newer guys just dont have the touch. I lost my 63 Corvair keys years ago. 20 minutes with the right locksmith and $80 later he punched a key using my glove box lock! I was impressed!
blkcorvair is offline   Reply With Quote
Old 12-08-2011, 10:48 PM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
About 5 minutes with a sawzall from behind and you are done. Just cut it right off if you aren't saving it anyhow.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-08-2011, 11:58 PM   #7
rpmerf
rpmerf's Avatar
you probably could had picked the lock in under 5 min. Its hard to believe the locksmith couldn't make a working key....
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 12-09-2011, 02:10 AM   #8
sanford66
sanford66's Avatar
I just had to do this same thing a few days ago. The key broke off in the ignition on the 72 Custom Deluxe i just bought. I tried to get the lock cylinder out by turning the cylinder to the left past the acc. position, insert wire in tiny hole, etc.etc...fought it for about an hour, no luck. I finally went and got the 1/2 inch drill, hammer, and small punch and went after it. It came out in about 5 minutes after that, but i did have to replace the ignition switch because it got destroyed in the anger of the moment. Never underestimate the power of a big drill! Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
