Old 12-08-2011, 11:42 PM   #1
doobiebro
doobiebro's Avatar
High hump or low hump..That is the question?
Okay guys I ordered a rubber floor mat for my 1960 truck and I told the sales guy the truck had a 235 engine, 3 on the tree and he says you have the low hump for sure....FINALLY after being on back order (2 weeks) received it and layed it on the driver side and fit perfect. So I had to cut a hole in the center to slide it over the custom shifter and this is what it looked like. Did a search on this great forum and found out the high hump is bolted on just like mine. Is it possible to have the high hump with the same description the sales guy gave me or is he full of s..t?? I also returned the rubber mat and received the right one a month and 3 weeks later..... What a drag?
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 12-09-2011, 02:00 AM   #2
Captainfab
60-66 Nut
Re: High hump or low hump..That is the question?
You have the high hump. Your truck may have been converted to the high hump since you no longer have the 3 speed.
Old 12-09-2011, 03:34 AM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
My 1960 GMC originally came with a 3 speed column shift and it also had a high hump from the factory. Although perhaps all GMC's came with a high hump, I don't know. I made the same mistake 20 years ago with my first mat. Received a low hump mat and cut a hole for the shifter. Fortunately the supplier took it back because at the time they didn't indicate there were actually two different sizes to pick from.
Old 12-09-2011, 11:58 AM   #4
Corts60
Just here to tinker
Corts60's Avatar
My '60 GMC had a 3 speed on the column and also came with a high hump tunnel; my '60 GMC Suburban has a high hump and 4 speed.
Old 12-09-2011, 12:10 PM   #5
doobiebro
doobiebro's Avatar
Captainfab when I got the truck 10 years ago it was all stock and it doesnt look like any conversions were made.
Old 12-09-2011, 12:19 PM   #6
doobiebro
doobiebro's Avatar
Markeb01 I sent this same pic to the vendor and he verified it was a high hump but he made arrangements to pick it up and he sent me the correct one...Good thing. Although the process took forever the vendor was cool about it..
Old 12-09-2011, 05:36 PM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
my 61 chev 3/4 ton had a 3 speed on the column and a high hump
Old 12-09-2011, 10:09 PM   #8
brawley
Easy Does It
brawley's Avatar
I have a 63' it came from the factory with a three on the tree and had a low hump ??
brawley is offline   Reply With Quote
Old 12-09-2011, 10:12 PM   #9
SCOTI
SCOTI's Avatar
What vendor if you don't mind? Care to comment on the fit quality?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-11-2011, 02:31 AM   #10
doobiebro
doobiebro's Avatar
SCOTI I got the rubber floor mat from Brothers. It was on sale and it fit like a glove especially if you still have the buttons that hold the mat in place. Only regrets is I wish the mat covered the whole floor (under the seat) since I layed dyna mat. Didnt want to go with carpet since I live in the desert. Will need to post a pic when I get a chance.
