Old 12-09-2011, 11:00 AM   #1
MikeN
MikeN's Avatar
Heater Blower - 64 C10
The blower fan on my 64 now works only on the highest speed. The motor was replaced a few years ago, and is still quiet and seems to function normally...but only on the highest speed. Is this likely a problem with the blower motor, or could it be the switch? Or something else?
MikeN is offline   Reply With Quote
Old 12-09-2011, 11:20 AM   #2
1963c-10
1963c-10's Avatar
Re: Heater Blower - 64 C10
I think its your heater switch on the dash. That controls the speed of the blower motor.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-09-2011, 12:48 PM   #3
Clownpuncher
Clownpuncher's Avatar
Do these trucks have blower motor resistor's that are seperate from the switch? If so I would think it's your resistor. If one is bad it send's full power to motor only allowing the highest setting to be used. Atleast that's what I replace all the time on most cars with the same symptons.
Good luck
Clownpuncher is offline   Reply With Quote
Old 12-09-2011, 03:11 PM   #4
1963c-10
1963c-10's Avatar
Yes, the resistor mounts on the heater box inside the cab, should glow red when hot.
Old 12-12-2011, 02:53 PM   #5
MikeN
MikeN's Avatar
This is helpful guys, thanks.
Old 12-12-2011, 07:00 PM   #6
rideblue00
rideblue00's Avatar
Could you elaborate on why/what that means? I never knew what that thing was.
rideblue00 is offline   Reply With Quote
Old 12-12-2011, 10:13 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
The resistor mounts on the back (firewall side) of the heater ducting. That is most likely what is causing your problem. When the resistor fails, high speed works but slower speeds do not, since power flowing through the resistor is what slows down the fan motor. If you follow the wire loom to the back of the ducting, you should be able to "feel" your way around to unplug the harness from the resistor, and then pop the resistor out of the ducting. It just snaps in place.
It appears however that most of the aftermarket suppliers are only selling the later version which is attached with screws. This may require either modification to fit the spring retainers, or installing it with screws.
Here's a schematic showing where it goes:
Old 12-13-2011, 02:33 PM   #8
MikeN
MikeN's Avatar
That is really helpful, thanks!
Old 09-07-2012, 12:40 AM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
My resistor on my 66 fell apart.
Classic Parts has them for sale:
http://www.classicparts.com/1960-72-...ctinfo/68-375/
66 C20 Service Truck:
