12-09-2011, 05:45 PM | #1 |
1961 crewcab
sectioned crossmember
any ins and outs on sectioning the front crossmember?
I have lots of time, but no cash so no dropmember... page 3 of dinos "a suburban joins the herd" thread has some good pics. questions: how and what bracketry for the raised upper control arm mount? what about the motor mounts? ( will be for a V8) how about the steering?-does it need to be moved? any other issues?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
12-09-2011, 08:37 PM | #2 | ||||
Re: sectioned crossmember
The same notched x-member required alot more clearancing (& shims to reverse some of the notch) to work in my 68 chassis but then didn't require the shims when installed into an 89 chassis (yet had the same clearance). The notched x-member was a 73-80 vintage. Once the x-member is notched, there's no access to the upper a-arm studs for servicing. In the OE location, there are access holes in the frame. Tack them in place to make sure they don't spin or be prepared for the extra effort if they need servicing as they're too high to re-drill 'new' access holes. Verify your planned engine oil pan depth. I originally set my notched x-member up in a 68 chassis using a sbc & was ok. When I swapped it to the 89 chassis, the BBC OE truck oil pan was now approx 1" below the lowest portion of the x-member.... NOT GOOD! I had to get a smaller depth car pan to keep the x-member just slightly lower (barely @ that). You'll likely need to relocate the upper shock mounts for better shock length dimensions.
12-09-2011, 08:59 PM | #3 |
chevy only
good info, i had good luck with the one i did. i ran it for a long time... til nate had the idea about the dropmember, i step my control arms which help out on the chamber issues
CHEVY ONLY... Nothin Else ! |
12-09-2011, 09:11 PM | #4 |
Funny this comes up now. I just picked up a spare for pancaking the other day. I am thinking I'll move it forward 1" at the same time, just to be sure it's not too easy
12-09-2011, 09:53 PM | #5 |
Are you planning the R&P upgrade too then? I just don't see moving it forward w/the OE box & links.
12-10-2011, 08:04 PM | #6 |
Still in the design phase. I could go that route. What's the issue with the box?
Posted via Mobile Device |
12-10-2011, 08:20 PM | #7 |
hope these pics may help. Raised 2" with performance online motor mounts cut and welded.
This is how she sits with 2.5" spindles and cupped lower arm with bags (rear was up 2" in pic) |
