64 heater box
For some reason i cant figure out why i cant pull the top off to change the heater core. The first cover came off fine but the second one seems to be stuck in the back. I know all of the screws are out, that i can see any way. Any ideas?
Re: 64 heater box
somebody glued it shut?
![]() Join Date: Aug 2008
Re: 64 heater box
pics?
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 64 heater box
Sometimes they seem to hang up where they are attached to the firewall. Could also be, someone used an adhesive on the seal like dthela mentioned.
Re: 64 heater box
the best seal i found for the box is flexible black electrical sealant soft rubber. stays soft and tacky forever
Re: 64 heater box
by the way, what 2 covers, only one right?
Re: 64 heater box
I'll get pics later today.
Re: 64 heater box
On my 65, I had to remove it from the firewall to get to 4 screws you cant see or get to with it on the truck.
#9 | |
Re: 64 heater box
Thanks. |
Re: 64 heater box
I was suprised by how many screws they used to hold it together. Seems like they could have cut the number in half.
Re: 64 heater box
Thats what i was thinking.
Re: 64 heater box
I am having the same problem. I removed every screw i could see. I just found the ones on the inside of the cab through the firewall, did you get yours off after removing those??
#13 |
Re: 64 heater box
Pull off the 2 or 3 bolts from inside, then remove the whole unit from the engine compartment. Then you will see the rest of the screws.
#14 |
Re: 64 heater box
I see that the topic is the heater core. Mine isn't working too good neither. Do I have to replace the entire box and core or do I have to just open the flux capacitor and replace the core itself?
[B][I]1965 Chevy C10 SWB w/350(68-79), 305 H.O Heads, Edelbrock Performer 1406 600 cfm carb, Torquer II Manifold, AC Delco HEI, TH400, Flowmasters,3.07 gears 2005 GMC Yukon XL Denali w/Mangnaflow Exhaust 1983 Cutlass Supreme w/ 350, cam, Holley 650 cfm, Street Dominator intake, carb spacer, hydromatic, Flowmasters Patriots always talk of dying for their country but never of killing for their country. |
#15 |
Re: 64 heater box
probably full of junk, take it out clean it and boil it out.
#16 |
Re: 64 heater box
I'll do that dthela. Boil it out with what? How do I do that?
#17 |
Re: 64 heater box
Yes it did.
