Old 12-09-2011, 10:10 PM   #1
HWS
HWS's Avatar
Doing a Full Vert Conversion on my K5. Need some measurements Please..
Hi everyone I need some measurements for a Full Convertible conversion on my '78 K5 and was hoping someone could help me out....
Im gonna be cutting my doors and need to know what the distance is from the exterior door handle up to where I need to cut... and I also was wondering if the top part is cut flush with the wing window frame..??
Here is a picture of what Im talking about...
HWS is offline   Reply With Quote
Old 12-10-2011, 01:54 AM   #2
Jonboy
Slots go on anything!
Re: Doing a Full Vert Conversion on my K5. Need some measurements Please..
the lower cut on the door (above the handle) is cut straight with the window frame. You will have to cut the belt molding also. For the cut above the vent glass, it goes straight up, then makes about a 45 degree angle. If you buy the seals, it will be pretty self explanatory. Also, make sure you reinforce the rockers after cutting the top. It will want to flex between the doors and quarters.
Where did you find that pic? looks like a sweet Blazer.
1974 Jimmy- 5.3/4L80e/NP241
Old 12-10-2011, 07:54 PM   #3
HWS
HWS's Avatar
I will be putting in a full cage so hopefully it will stiffen it up enough without the rocker boxes. Thanks for the info!!!
Old 12-10-2011, 07:57 PM   #4
HWS
HWS's Avatar
Probably a dumb question.... but what is the belt molding?
And the pic I just found it on a google search
Old 12-11-2011, 02:20 AM   #5
tobiahr
tobiahr's Avatar
The belt molding is the seal that surrounds the window at the door
tobiahr is offline   Reply With Quote
Old 12-11-2011, 10:15 AM   #6
Jonboy
Yep. The original one makes a turn at the end of the dor. Just cut it to fit the cap. There is supposed to be a metal insert that goes in the hole at the end of the door, but whoever sliced my '77 didn't bother with that. They used a really long (4"?) sheetrock screw, and screwed the cap to the window channel. It worked, I guess.
Old 12-12-2011, 01:03 AM   #7
HWS
HWS's Avatar
Ok cool thanks again for the info
Old 12-14-2011, 02:38 PM   #8
mickeykreg
mickeykreg's Avatar
Hey, when you get about done with this conversion I'd be super interested in stopping by to see how you've done things. Let me know if thats cool.
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD
'77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD
rust repair on the '77
http://67-72chevytrucks.com/vboard/s...d.php?t=740291
mickeykreg is offline   Reply With Quote
Old 12-17-2011, 10:20 PM   #9
HWS
HWS's Avatar
Yeah for sure I hope I can get it done by next summer. Ill post up pics when I do it and when Im done.
