Old 12-10-2011, 02:16 AM   #1
DnvrJay71
DnvrJay71's Avatar
late 70's 3/4 ton 14 bolt?
Will i have to shorten it to get it to fit my 71 K5? I know I'll have to replace the mounting brackets, but I found this set of 3/4 ton axles for about 300. I want to upgrade at some point but didn't know if these would work or would be worth it?
DnvrJay71 is offline   Reply With Quote
Old 12-10-2011, 10:28 AM   #2
Mike C
Mike C's Avatar
Re: late 70's 3/4 ton 14 bolt?
No need to shorten. Re-locate spring perches and shock mounts. I swapped in a semi-float and moved the mounts but used the shock mounts off an old 12 bolt, I liked them better than the later style. I built a jig out of angle iron to get the mounts on at same pinion angle and the shocks in the right place.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
