69 250 electric choke wiring?
Hi Gang, I have a stock I6 250 but has a mid 70's rochester 1 bbl with electric choke. Its starting to get cold here and truck is taking longer to start. I would like to use the electric choke but am not familiar with wiring of it. Any suggestion of how to run a wire or to tap an existing line already in compartment would be great. thanks
1972 C20 350/ 350 auto No Rust |
Re: 69 250 electric choke wiring?
Run a dedicated wire from the fuse panel. Should be a couple that are marked as unfused. Use 12 gauge wire.
I will give it a try. Thanks
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Make sure it doesn't have power when the key is off. If it does it will run your battery dead. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Sierra Grande Club
I think the M&H wiring I'm using is getting it from the starter solenoid - 12V when the key is on.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Tags |
69 electric choke wiring |
