Old 12-10-2011, 11:39 AM   #1
JRANGER
JRANGER's Avatar
HELP! Cant get cab bolt off
So im trying to get my new floor support beam installed but i cant break the bolt free that attaches the cab to the frame
Ive used a ton of WD40 and all i have is a socket wrench...ANy ideas?
I could cut a notch in the support to go around the bolt and im sure it would be fine but i am trying to do this the right way....
What do you guys think?
JRANGER is offline   Reply With Quote
Old 12-10-2011, 11:44 AM   #2
71swb4x4
71swb4x4's Avatar
Re: HELP! Cant get cab bolt off
Cut it off.
What tools do you have? Hack saw? Reciprocating saw? Angle grinder with cutoff wheel? Dremel with cutting wheel? Torch?
If no cutting tools drill the center of the bolt or head out as far as you can and then hit the head or bolt with a cold chisel or even a large screwdriver if that's all you have.
Whatever you do wear gloves and eye protection.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-10-2011, 11:46 AM   #3
JRANGER
JRANGER's Avatar
Originally Posted by 71swb4x4 View Post
Cut it off.
Ok...Well what kind of bolt do i need to replace it...And what kind of NUT?
Im using an angle grinder with a diamond cut off wheel and yeah ive been using gloves and eye protection the whole time
Old 12-10-2011, 11:52 AM   #4
kris's66lwb
resident wrencher
A grade 8 and the nut should be in the cab mount
kris's66lwb is offline   Reply With Quote
Old 12-10-2011, 05:59 PM   #5
baclay9
I had to cut all 4 of mine off. I had to cut holes in my floorboard so I could just use a regular nut.
By claypool782 at 2011-12-03
Then we made this little filler piece so you wouldn't feel the hole with the carpet on. It has a washer welded to the bottom of it so it cant come off the hole
baclay9 is offline   Reply With Quote
Old 12-10-2011, 06:02 PM   #6
kris's66lwb
resident wrencher
Tahts a good idea if reusing the cab
Old 12-10-2011, 08:39 PM   #7
cabcorner
I usually cut the head off the bolt then pound on the bolt til I drive the nut up through the hole I cut in the floor. Then I put the nut in a vise and heat it until its cherry red . Then I unthread what's left of the bolt with visegrips . Then I reassemble the supports and floor the way it was put together originally. I reuse the original nuts because they are 1-1/2" x1-1/2" cage nuts.
cabcorner is offline   Reply With Quote
Old 12-10-2011, 08:45 PM   #8
JRANGER
JRANGER's Avatar
yeah i couldnt get them, couldnt find new bolts so i notched the supports and let them lap over the lip in front of the screw...It will be welded so im sure it will be fine
Old 12-11-2011, 05:32 PM   #9
JRANGER
JRANGER's Avatar
Someone give me some info on these botls Grade 8 but length???? These babys gonna get cut out.....I just busted myself in the face giving this thing everything I had after letting it sit for a day in WD40 lol
Old 12-11-2011, 05:54 PM   #10
Goldfinger
Goldfinger's Avatar
get a cheap propane torch and heat it up. also add a cheater bar
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 12-11-2011, 05:56 PM   #11
JRANGER
JRANGER's Avatar
LOL but what about the bolt sizes?
Old 12-11-2011, 09:20 PM   #12
Goldfinger
Goldfinger's Avatar
I can't remember what exactly it was but i'm thinking 4 inches at about 9/16ths. however i'm not sure
Old 12-12-2011, 10:58 AM   #13
donut
donut's Avatar
Once you cut them, you'll have the size. I don't remember it off the top of my head.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 12-12-2011, 04:23 PM   #14
85sierraclassic
85sierraclassic's Avatar
i thaught the cab bolts were just standard thread 1/2" bolts length depends on what style body mount i think maybe not
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 12-13-2011, 08:42 AM   #15
xrcr
claypool, I like your idea. I just made small panels and siliconed them.
xrcr is offline   Reply With Quote
Old 12-13-2011, 10:03 AM   #16
jitteryguy
GoatLube Experss
jitteryguy's Avatar
the bolt is 1/2X13 , you will need to check the length after you get it out. if you can get a grinder into the top of bolt cut any excess thread's of then give it one more try befor cut'n the bolt out.
if you have to cut it out try to get the weld nut out as well, a regular nut will work fine but if ya want it to look like the old one you can a square nut at any hardware store and weld it back in.
either way just weld the nut in then you wont need another hole in the floor to access the nut.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-13-2011, 01:04 PM   #17
Zebb
Zebb's Avatar
3.5" long.
Zebb is offline   Reply With Quote
Old 12-13-2011, 06:48 PM   #18
piecesparts
Parts and more parts
piecesparts's Avatar
Use a very effective liquid fire wrench for the final approach to this problem.
Frank
piecesparts is offline   Reply With Quote
