Old 12-10-2011, 01:11 PM   #1
Stefan.
Stefan.'s Avatar
Motor Oil
hello,
how much motor oil must in a 283 V8?
what type oil is in the rear axle?
Stefan
Stefan. is offline   Reply With Quote
Old 12-10-2011, 01:27 PM   #2
bama63
bama63's Avatar
Re: Motor Oil
5 quarts in the engine and 85w90 gear oil, if you have a limited slip then use the 85w90 for limited slip differentials or the gm limited slip additive and standard lube
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 12-10-2011, 02:11 PM   #3
Stefan.
Stefan.'s Avatar
Re: Motor Oil
OK thanks!
Old 12-10-2011, 02:56 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Motor Oil
Just for clarification the 5 quart capacity includes what is in the oil filter. Or in other words 5 quarts total. If you have the old bolt on steel canister type cartridge filter, you should put 4 quarts in the engine and run it for a few seconds to circulate the oil into the filter. Then add the 5th quart to the engine.
If you have an adapter for a spin on filter, add one quart to the filter before installing, and the other 4 in the engine.
Old 12-10-2011, 03:10 PM   #5
Stefan.
Stefan.'s Avatar
Re: Motor Oil
all right!
thanks
