12-10-2011, 02:30 PM | #1 |
Varnish on wood beds, how many coats under?
Hey guys, how many coats of varnish did you put on the back of the wood? I know a lot of you put 6-11,000 coats on the top... lol
But how many on th back side of the wood? thanks for any info...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy? |
12-10-2011, 03:15 PM | #2 |
Re: Varnish on wood beds, how many coats under?
So I should have put this in the General section huh? can some move? thanks...
12-10-2011, 03:35 PM | #3 |
i recommend the same number of both sides.. same as outside furniture.. if the back can adsorb morns e humidity then the front, you get a bad warp.. bolted tight as the beds are, it shows up as a crack.. what are you using? i use the best clear deck sealer i can find.. follow the instructions and go at least three coats..all sides, including the ends
12-10-2011, 03:53 PM | #4 | |
I'm using Cabot Spar Varnish. I was thinking 3 coats on back and sides would be enough to keep the moister out, with more coats on top for a shinny looks and UV protection. I see your point, but do you think I would have that problem with 3 on the back and sides and 6ish on the front? thanks for the help...
12-10-2011, 05:09 PM | #5 |
Old Heap Driver
Don't forget the ends and edges.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
12-10-2011, 09:19 PM | #6 |
For sure... thanks for the input.
Anyyone else with varnish wisdom to share?? Posted via Mobile Device
