Old 12-10-2011, 02:45 PM   #1
Tmwoodall
Running engine with A/C or PS lines
I am hours away from finally being able to fire (I hope) my engine for the first time, but I have changed to a serpentine setup. So I am wondering if I can actually safely fire it without AC Lines or PS lines hooked up.
When I fired the old engine we just left those belts off, now with the serpentine kit on there so that isn't a possibility. For the PS I have to buy new lines to fit March's remote reservoir. For the AC, I don't have the cab on the frame or clean lines to install.
So is it safe to run the AC compressor without power but open connections, and the power steering pump totally open?
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 12-10-2011, 02:50 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Running engine with A/C or PS lines
The AC would be fine as you can turn off the AC switch + it's should have a safety valve to prevent it form coming on with no Freon (so clutch will not engage).
The PS pump is another sorry.
I wouldn't run it dry.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
