69 C-10 voltage regulator?
my son and I recently did a motor swap in his 69.
We installed a small block for a 75 truck. We bought a new alternator, and new HEI dist. When using a more modern alternator, one that has an internal regulator, shouldn't I be eliminating the external regulator? If so, how do I make the proper wiring connections? Thanks in advance, Mike |
Re: 69 C-10 voltage regulator?
You should find what you need described here:
http://67-72chevytrucks.com/vboard/s...d.php?t=119379 |
Heres the link to the Faq section of the forum that I used to eliminate my voltage reg.Hope this helps y'all out
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 |
Thanks guys. That's exactly what I am looking for.
I must have used too many words when trying to do a search myself. This site is a HUGE help!! Thanks again, Mike |
#5 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
http://67-72chevytrucks.com/vboard/s...d.php?t=495265
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Sierra Grande Club
Or you can do it the easy way.
7555 ALTERNATOR CONVERSION KIT, EXTERNAL TO INTERNAL REGULATOR CONVERSION HARNESS ("SI" SERIES) $19.00 Pic NOTE: for use with 1972-84 non-serpentine belt ("SI" series) internal regulated alternators 37787 ALTERNATOR CONVERSION KIT, EXTERNAL TO INTERNAL REGULATOR CONVERSION HARNESS ("CS" SERIES) $19.00 Pic NOTE: for use with serpentine belt ("CS" series) internal regulated alternators (link here) The best way is to go with their complete harness, to include headlight relays, electric choke, internal regulated alt. This will eliminate any future headaches. It's not like the Painless system, it's literally plug & play as it uses the same color codes and connectors.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
