67 Stepside added to the Collection
Just picked up this 67 last week. I have wanted a 67 small window truck for a long time. It has been off the road for 8 plus years. It was stored in a warehouse for the last 5 years, but I'm sure it has spent many years outside. This week I took out the plugs cleaned them and sprayed marvel mystery oil in the cylinders. I also had to replace the ignition switch as I had no keys. Today I changed the oil, hooked a fuel line to a gas can, sprayed some starting fluid in the carb and she fired right up. I could only keep it running on starting fluid. It appears the fuel pump is not working. I know a lot of people love to modify their trucks, but it is gratifing to get an old stock one running again. I'm just not sure if I want to sink money into the 6 cylinder or just throw one of the V8 engines that I have laying around in it.
68 4wd Stepside 69 2wd Stepside Project 71 2wd Blazer Project 72 2wd 3/4 Ton Project or Parts? 73 4wd Blazer |
Re: 67 Stepside added to the Collection
Replace the fuel pump and run it as is! I wouldn't change a thing.
Ray |
I love it!!
Well except for that huge dent in the driver door. ![]() Love the color and the inline 6 is definitely cool. Nice save. Keith |
Sweet
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
![]() Join Date: Sep 2004
Im digging it. Leave it the way it is and run it.
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
Id leave it too.
How many options does that thing have. Very few I would say. V8s are overrated in the best of times. Especially when it takes a thing called work to put one in. Roll with the six. |
Florida Edition
![]() ![]() Join Date: Oct 2010
I like it too. Run with the 6 for a while.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Ditto!
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
![]() Join Date: Nov 2011
Yep steelies and caps and " Junksavers Custom shop" stenciled on the doors and petina`d like the rest of the old girl! Sweet find !!
Here's the dilemma I'm stuck with. I like the cool simplicity of the 6 cylinder, but I'm afraid the motor is just wore out. I can turn the motor by hand just by grabbing on to the fan blades and it needs minimum of new fuel pump, carb rebuild, ign wires, belt, hoses and vc gasket. When I had it running it was blowing smoke out of the breather cap and pcv grommet. Option 2 is I have a 69 stepside that I need to replace the frame on(see pic). It has been in the back of the shop for about a year and a half. It has a nice small block and I need to pull the motor out anyways. I could pull the motor and exhaust out of the 69 and put it in the 67. It would just involve a little time, but next to no money. This would also get me motivated to do the frame swap on the 69.
I just drilled out the locking gas cap on the 67 and it looks like I will be needing a fuel tank. It sure had a pleasant odor coming out of it.
#13 |
VA72C10
![]() Join Date: Mar 2008
Cool truck! Might just be the bad gas in the tank and not a fuel pump...try running it off a gas can for a bit to see if the pump is working....
And if you can't find a tank local I have a few for sale up in Richmond.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#14 |
Today I pulled off the valve cover to see how the inside of the motor looked. It is amazingly clean for 126k miles. Usually an old motor like this would be gummed up especially the way the outside looks. Tomorrow I'm going to get a new fuel pump and see if I can get it to run. Hopefully this will be a good motor, if not it's V8 time.
#15 |
![]() ![]() Join Date: Jan 2011
Did the dent in the driver's door get into the rocker too? Not that it's a big deal to fix but I agree, most of that in the door would pop right out.
Good looking truck man. I'd focus the money on getting it dependable and save the 6 if you can. Nothing wrong with a 6cyl truck. .. those old motors are pretty strong.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#16 |
The dent got into the rocker slightly, but not too much. Even though the door is heavily dented, it opens and shuts just fine and the window rolls up and down.
#17 |
Maybe just leave the dent ?
![]() I think it adds character. Maybe a big bull ran into it while it was in the pasture sometime in the last 43yrs(?). Man I wish these trucks could talk sometimes. Posted via Mobile Device
#18 |
![]() Join Date: Sep 2007
I got the same deal you did. i just picked up a 67 short step veryvery few options anda complete 250 sitting for about 14 years. motor turns by hand just fine and I got it to backfire a couple times but she wont start up!!!. neat finds huh?
1967custom |
#19 | |
![]() Quote:
However, these 6 cylinders require more patience to work on than a V8 and I would strongly recommend having the factory service manual on hand as a reference prior to doing any work on the six. I'd suggest you install an electronic ignition...it makes a world of difference in driveability...along with wires and plugs. I'd recommend purchasing parts through Tom Landon's Stovebolt Engine Company...he is more than willing to spend time with his customers to make sure they get what they need. Do a carb overhaul for sure and replace the intake / exhaust gaskets while you are at it. Although a little tedious labor wise, it would be a good idea to replace the timming gear set and install a new oil pump. It may seem like this is quite a bit of work...but it really is not...that is...if you do it all at once. The big plus is that once you set one of these 6 cylinders up...they are really dependable...and get decent gas mileage albeit they are not too strong on power...about 60 to 65 max on the highway but for around town driving the six has plenty of power. |
#20 | |
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
#21 |
Man i would have loved to get that gmc!! Wanna trade?
1967custom |
#22 | |
Autoblueprint Thanks for the advise. I actually find the 6 cyl. easy to work on. I had my 1st chevy 250 in a 67 firebird about 23 years ago and I use to own a 67 C30 Tow Truck about 18 years ago. It had a 250 with the sm420 4 speed and 5.13 rear gears. It would tow just about anything, but it had no top end speed.
#23 |
I installed a new fuel pump today and that took care of the fuel delivery problem, only to create a new problem. The carb is leaking fuel. It looks like someone beat on it with a hammer and cracked the housing. What really sucks is I had a 66 I was parting out this summer that had the 250 in it. I wish I still had it now. Well I guess the carb search begins.
#24 |
I have a holley reman original style carb that was only on my truck for around 5000 miles or so you can have if you pay shipping
#25 |
I may do that. Can you PM me your number and I will give you a call. Thanks
