12-10-2011, 08:31 PM | #1 |
Is my oil pressure Low?
1972 307 in 69 C10. See below pics. Low reading is at idle when warm. High reading is driving at normal highway speeds. I have read that hash marks on gauge are for O-15-30-45-60 psi. If that is correct then I idle at 5 or 6 psi and at about 30 on freeway. Is this low or normal for a high mileage engine?
Runs smooth no knocks. Thinking of rebuliding before I paint but why do it if engine is Ok? |
12-10-2011, 08:40 PM | #2 | |
Re: Is my oil pressure Low?
12-10-2011, 08:51 PM | #3 |
As a rule you need 10psi for every 1000rpm for a stock small block chevy.
72 Chevy K20 NV 4500 /dana 60 /gm 14bt 72 GMC K10 Super Custom 84 GMC K35 SRW 454 t400/205 03 Ram 2500 w/Cummins |
12-11-2011, 07:43 AM | #4 |
i'd say that is very normal for a high milage smallblock chevy engine and nothing to b overly concerned about
it might slightly raise pressure if you run a 20/50 oil
12-11-2011, 09:31 AM | #5 |
x2 on cdowns comment.
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
12-11-2011, 10:52 AM | #6 |
its all about the +6 inches
that looks like a tired and worn out motor.
She could last 'X' more years... or days. |
12-11-2011, 11:45 AM | #7 |
One of the First
Couple of questions: Is the guage a 60 or 80 psi type. Do you have a high volume oil pump? What grade oil are you running?
If its a 80 psi, that looks fairly normal after the oil has been ran awhile. If its a 60 psi, its a little low if idleing at 0800 rpms. A high volume will increse the oil pressue on a mechanical guage. Oil vicosity also has effect on pressue. In the past, 10-30W runs about that range after warmed up. I run straight 30w here in FL and it stays higher on a 60 psi guage. I would run it until you get all symptoms to rebuild or replace. ie: fouled plugs, exhaust smoke, noise power and low compression when checked.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
