Old 12-11-2011, 01:06 PM   #1
Laid_Out_50
Laid_Out_50's Avatar
Fire wall or frame mounted
I know that when it comes to the location of mounting the brake booster master cylinder its all personal preference. I am putting a Nailhead in my truck and am stuck on where I should put the MC.
Laid_Out_50 is offline   Reply With Quote
Old 12-11-2011, 02:14 PM   #2
54foster
Re: Fire wall or frame mounted
Have you seen the pictures of the under the dash mounted MC? I think I am leaning this way.
54foster is offline   Reply With Quote
Old 12-11-2011, 02:32 PM   #3
bajabob
bajabob's Avatar
I mounted mine on the frame. Its where the original one was mounted and just cleans up the engine bay so much nicer. I am sure it will be a little harder to work on but I like the "clean" look of an engine bay w/o the booster sitting there.... just my 1.5$
that should be a sweet engine swap with the nail head...
bajabob is offline   Reply With Quote
Old 12-11-2011, 04:28 PM   #4
parkwood
parkwood's Avatar
I have to agree mounting the booster on the frame cleans the fire wall up great. These two are from TCI and bolt right up and go thru the stock hole in floor.... very nice..
parkwood is offline   Reply With Quote
Old 12-11-2011, 04:37 PM   #5
LEEVON
Moderator
LEEVON's Avatar
Underfloor if you can. I had mine there but the pedal hit the clutch fork so I had to move it to the firewall. If you want the underfloor bracket let me know, I'll sell my un-used but no booster.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-13-2011, 01:12 PM   #6
oldcouple
oldcouple's Avatar
I paid a guy to install the underfloor one, uses Mustang parts, it never worked right, found out it was installed wrong. It always leaks, not sure why, I blame the F... parts.
oldcouple is offline   Reply With Quote
Old 12-13-2011, 06:26 PM   #7
mr48chev
mr48chev's Avatar
On the frame. I've hand mine on the firewall and it added way too much clutter and ugliness. I can see if if you did a frame swap but with an original frame I'd keep it under the floor.
Old 12-13-2011, 06:31 PM   #8
Spackle100
Aesthetically, I'd go frame mounted. But apparently with the different pedal designs, the firewall setup gives you more pounds of force per square inch when you push down on the pedal. Which means it is supposedly safer and gives you better stopping power.
Spackle100 is offline   Reply With Quote
Old 12-13-2011, 06:34 PM   #9
booger1949
i put mine on the frame but i extended the brake rod so the booster an master r under the seat area, an i have all the room in the world if i need to work on it
booger1949 is offline   Reply With Quote
Old 12-13-2011, 07:36 PM   #10
72Mountaineer
72Mountaineer's Avatar
Booger...got any pics and info of that setup. Everyone else, got any pics of how you run your dual exhaust around that setup?
72Mountaineer is offline   Reply With Quote
Old 12-13-2011, 08:39 PM   #11
parkwood
parkwood's Avatar
These are from the bottom of a '51 suburban...
Old 12-13-2011, 09:05 PM   #12
Kabwe
Certified Car Nut
Kabwe's Avatar
Yeah I've seen that suburban and that thing is sweet.
I also plan to going on the frame with a hydroboost unit.
Kabwe is offline   Reply With Quote
Old 12-13-2011, 09:19 PM   #13
parkwood
parkwood's Avatar
Kabwe thanks..
Old 12-13-2011, 09:46 PM   #14
upon1
upon1's Avatar
What did you guys do that have fully boxed frame? Does the mc interfere withe the trans mount?
"Lifes to short to drive an ugly truck."
Project 55 To Life
http://67-72chevytrucks.com/vboard/s...d.php?t=432994
upon1 is offline   Reply With Quote
Old 12-13-2011, 09:52 PM   #15
Scottshotrods
Throw it under the dash of your truck there is plenty of room and it will give you more room for your tranny mount.Just a idea!!!!!!!!!!
Justin
Scottshotrods is offline   Reply With Quote
Old 12-13-2011, 10:24 PM   #16
parkwood
parkwood's Avatar
The one i posted here of the bare frame can be welded to a boxed frame.. you would just take off the bracket that bolts to the inside of the frame...
Old 12-13-2011, 10:39 PM   #17
booger1949
ill have to find the pics for ya. but the break assembly is pretty strait foward, i pickd a spot on my frame that would have the ms out the way an easy for me an made my own brakets to mount the ms, i used a brake rod off a ford 3000 tractor an installed it in a steal pipe that was a tad bigger than the rod an ran the pipe as long as i could so the rod would not bend in a panic stop an have been drivin the truck for 3 years an it works great
Old 12-13-2011, 11:03 PM   #18
parkwood
parkwood's Avatar
check out www.abspowerbrake.com look on page 116 and you'll see a few of the brakes with the booster and m/c mounted back under the seat..
