![]() Join Date: Dec 2006
Transfer case hitting bottom of cab???
I just re- installed my transfer case today, and the top of the transfer case is now hitting the bottom of the cab floor. I did get a new to me crossmember out of a used truck, as my original crossmember had been bent. My truck is a 72 K10, and I am not sure exactly what year or style of truck the crossmember came from, but they looked identical. Is there a difference between a 3/4 ton transmission crossmember and a half ton crossmember (4 X 4)? Also, the torque support bolt holes for the transfer case don't line up anymore, and it looks to be about 3/4 of an inch below the current transfer case location?
It seems to me that I must have gotten a 3/4 ton crossmember, and they are not interchangeable. Anybody know for sure? |
![]() Join Date: Feb 2001
Re: Transfer case hitting bottom of cab???
Probably answered over in the 4x4 forum better. I have lowered my TC about two inches lower that the stock location. You can bolt that cross member under the frame rails. You should have to without a lift. The little sleeves go on top of the crossmember also.
