front end on 77 c10 lwb 2wd help
okay im in need of a serious front end job and am looking forward to doing it myself this christmas break because thats the only time i can do it because im out of school for two weeks anyways
what does the front end consist of its all stock never been changed out and need to know if there is anything im missing i know for a fact my ball joints(upper and lower) need to be changed along with the following: control arm bushings sway bar bushings wheel bearings tie rods(inner and outer) what else is there? how hard is this job to do? what special tools will i need? |
![]() Join Date: Feb 2010
Re: front end on 77 c10 lwb 2wd help
You might consider replacing the idler arm and pitman arm. And the center link. Do you have a plan in mind for how you will replace your control arm bushings?
